Consolidated Slider Info Thread
I went for the Rocky Road step sliders. I have to say, I'm not super impressed.
I ordered on June 1, and paid upfront via PayPal. I didn't hear anything more until 7/29 I received a shipping notification. Of course, we were out of town for the week, on vacation. Anyway, it worked out that they were delivered on the second attempt by Fed-Ex. When I opened the box, it contained two step sliders, a ton of packing material, and nothing else. I called immediately, and was told that they would ship out the mounting hardware that day.
Later, when I was looking them over, I noticed the driver's side slider had a big gouge right on the front, obviously had been dropped at some point. Rather than go through a big hassle trying to return/exchange I just decided to get some spray paint at the hardware store, paint over the gouge and mount them since it wouldn't be noticeable once it was on the truck.
Hardware arrived today so I decided to mount them on the truck. Starting with the driver's side, I was only able to get three out of the six holes to line up with the holes in the frame. Both the front mounting holes and the lower rear mounting hole. The middle holes were both so far off that I wound up drilling a new hole in the frame and using a self tapping bolt they supplied for similar issues. I could not for the life of me to get the bolt started in the upper rear mounting hole.
The passenger side went quite a bit smoother with both the upper and lower holes lining up in the front and rear, but the upper hole on the middle mount I accidentally cross threaded and the bolt only went in about halfway the lower hole didn't line up very well and it doesn't have the threaded insert which is why they include the self tapping bolts, but I didn't want to drill another hole.
I primarily wanted these sliders to function as steps and not necessarily as sliders, so I am not too concerned about not having all the bolts in, but I wish I could get the upper rear bolt in on the driver side. I may have to try to slot the mounting hole in the slider a bit, but it will be a pain in the ass.
Edit- I picked up a new Dremel and a 90* attachment and was able to enlarge the hole without removing the slider. So now I have the bolts in both the upper and lower holes on the rear mount, which makes me feel quite a bit better about them. It looks like the rear mounting plate is bent or not square or something but I was able to get the bolt started and snugged down. I shot the bare metal with a little Krylon rust resistant paint before I put the bolt in.
They do look nice though....
I just installed a set of Shrockworks step sliders. I was undecided between these and the angled RSG ( which are angled out from the truck more than most). I went with the Shrockworks for a few reasons. Cost, availability (Instock) and my wife preferred the flat as a step. Customer service was great. Sliders got to me within a few days of ordering. Install took my about 1.5 hours. I would definitely recommend these to anybody needing steps and wanting sliders.
I also posted this on the Slider Recommendations thread.
If you have a 5th Gen, I recommend the 4xInnovations bolt-on sliders (Welcome to 4x Innovations - Hardcore Toyota Rock Crawling Armor). They are the strongest and best designed sliders for actual use.
I am a licensed Civil Engineer in NC, SC, GA, and AZ and have been doing engineering design for 29 years. When I wanted sliders for my “new to me” 2011 4Runner, I spent 6 months reading and researching everything I could find because I wanted something that was well made, strong, and affordable. I looked at everything from weld-it-yourself kits to save money to bolt-on and, frankly, nothing really compared to the build quality and strength that was evident in the 4xInnovations design. I could tell that these were built the way I would build them and that was what I wanted. You can tell that every opportunity was taken to make them stronger in a way that minimized the stress transferred to the frame rails. Pretty much all of the other bolt-on sliders attach with between 6 and 10 bolts per side, but these use 17 or more on each side. Watch the video on YouTube for more detail at YouTube. There is also a video on installation and a drop test video (which nobody else has done).
My only problem was that the website said 2014-2018 and my 4Runner is a 2011. I bugged Adam at 4xInnovations for about 4 months, sent him photos and measurements, called him and talked about the install, and finally we concluded that the sliders would probably fit my 2011 after all. I placed the order and couldn’t be happier. Installing them was a breeze (after three coats of bare metal primer and three coats of satin black). I did it myself using a floor jack with a 2x4 to spread the load and the only difficult part was getting the KDSS accumulator pulled away from the frame so I could slip the slider underneath it (it is pretty tight). Once everything was mounted, I added grip tape to the top (12”x2” 80 grit pre-cut strips from Amazon) and they look fantastic. I attached a couple photos below.
How many 4x employee's are on the forums?
Funny, I'm not an employee, I don't even have those on my 4runner.
However, they are the only company yet to show any testing of their product, and I appreciate that! Especially when I have seen "sliders" bend so much that they prevent doors from opening...
Any one have the RSG sliders in DOM? I've seen that it is an option but havent seen anything about them installed.
I am looking them or the ones from Caliraisedled. RSG had no lead times but I think they are weeks out now.
Real close to pulling the trigger on some Shrockworks step sliders.
Seems they have the best price with powder coating.
Look pretty strong too:
YouTube
YouTube
I ordered some shrokworks dimpled bolt ons before the 2020s started coming out and the lead times may have increased due to people wanting them for their new vehicles. Ordered and shipped within a couple days. I couldn't be happier with them!
P.s. you don't have to remove the gas tank skid. I simply unbolted the ones I could, undid the fuel tank skid, and slid the slider in. Make sure your tank is almost empty.
I'll have to go research kick out vs non kick out. I kind want something that doesn't stick out as much.
I like the looks and a bigger step. They do provide protection in certain instances where you need to be pushed away but it's not my main concern.
FWIW I had shrockworks sliders(and bumper and skid) on my Nissan Frontier before moving to the 4Runner. Loved the quality of them and they were SOLID. I would definitely buy shrockworks again.
Seems like a few just joined haha
I posted the pics of my 2011 4Runner and am just a happy customer out in South Carolina. I just did a bunch of research before I purchased and I really liked what I saw and am very happy. I think that 4xInnovations is located in Wisconsin and I have no affiliation with them.
DionicioLives
