Cooper Discoverer ST Maxx 255/80/17 Skinnies
Just put them on mine when I installed my lift. Switched from 255/75 to 255/80. No issues with speedo, syncs with phone GPS spot on.
You guys are killing me. I was all set on a sensible set of 255/75s, then I see the 255/80s are weigh only a few pounds more even though they are E-rated.
Can anyone confirm how tall these things actually are? I've seen everything from 32" to over 33"... I'd like my speedo to still be somewhat accurate with the tires and not zap too much of the power away.
Closer to the advertised size of 32.8 not over 33 for sure.
These are more of a skinny 285/70r17.
Not a taller and skinnier version.
Skinnies
Got the 255/80/17s mounted this past weekend with SCS SR8 Matte Gunmetal. The offset of the wheels and the tires' beefy lugs makes me forget I got 255s skinnies. Only one regret......I didn't get them sooner. Both tires and wheels look even better in person.
Wheels looks sweet! I can't decide between the SR8's, Ray10's or the FNW Overlander. But definitely going gunmetal. Also, ST Maxx is at the top of my list as well. Dig it man! Looks real sharp.
noob to the T4R world. i picked up a 10 TE in February and am in the market for new tires. does anyone have any experience with these on the 10-13 TE's? from my understanding the clearance's or issues should be consistent from 10-current?
Sorry nobody got back to ya. but yeah you shouldnt have an issue, the 10-13 TE matches the 14+ body lines, with the exception of the limited, (higher clearance rocker panels and front and rear bumper) so you should be good to go.
Had maxx 280 70r17's put on my 4th gen today - the handling is down right dangerous! I put them on the stock wheels from a 2016 t4r, so they are only 7" rims. Toytec Boss 3" lift that rpde fine with the 265's. I've read about a break in period that might have sloppy handling, and I haven't had it aligned yet, but no kidding, I will not drive it on the highway like this. It's scary. It drives like there is 10 pounds of pressure in the tires. This is my first set of 33"s, and I was expecting some change but...
Anyone else experience this??
Sent from my SM-G930V using Tapatalk
You're going to have to be a bit more specific. They aren't p-rated tires, so they aren't going to handle the same. They have taller sidewalls, so they may sway more. What tire pressure are you running? You haven't aligned it after the lift or just after the new tires?
Got it aligned today and it is somewhat better but not what i hoped for. The scary part is in the steering. At speed it is very slow to respond - like driving my grandma's Cadillac with 10lbs of pressure in the tires. The slow resonse turns into over steering then to over correction and then what feels like the fish tailing. I totally understand lifted truck on taller tires is going to lean and sway more but Is everyone on these tall skinnies just avoiding all emergency maneuvers?
Oh, it came from the tire shop at 45psi, after the sloppy handling I went up to the cold max of 80psi.
LOL 80psi? I can only imagine how that thing rides. I run around 38-40 psi in mine, they had mine set at 45 as well.
Have you ran aggressive tires before? Its not going to feel as stable as the p-rated tires. You have taller sidewalls as well as taller tread blocks, which are also squishy.
You can still do whatever manuvers you'd like. The tires aren't going anywhere, you aren't just going to spin off the road into oblivion. Try them a few times, if you don't like them, swap them for something different.
45psi and 80psi?
Well, try high 30's too and check back.
I run 255/75/17 Jeep GoodyearWrangler takeoffs, and while emergency braking is a bit squirmy, it is okay otherwise.
Assuming the tire shop didn't damage anything, and your car was just fine before swapping over, something else is amiss.
45psi and 80psi?
Well, try high 30's too and check back....
OK, dropped the pressure to 37ish and WAYYY better. Still pretty loose at 75mph, but not death defying. Thanks for the advice, never had loose tires fixed by having less air. I typically run max pressure in my Yaris and Prius.
Theory goes that at that max psi, the actual tire footprint becomes (in your case) noticeably narrower. The shoulder blocks which are on the very edge of the tire, designed for handling lateral loads, probably ended up not having great contact with the pavement. Lowering your psi meant they were able to work the way they were designed to, especially during the transition when the load goes from the centre of the tread (driving straight) onto the edge of the tire during lateral movement from turning.
Running max pressure on your Yaris and Prius serve only one pupose--to lower rolling resistance by way of smaller footprint. Your ride/comfort/NVH will be greatly improved if you were to run closer to the psi recommended on the doorsill.. probably 30-32psi.
I know that in autox, where ride quality is not prioritized, people run the max psi to give the sidewall additional stiffness to resist to rolling over, and therefore provide quicker lateral response and ultimate grip. That said, they do not run them at max psi all day--they chalk the sidewall, and lower their psi progressively, monitoring the chalk line until the sidewalls start to flex and roll over. They also reduce psi as morning bleeds to afternoon, to compensate for both increase tire pressures due to 1.5 minute runs, as well as the increase in ambient temperatures. They are also typically stripped of all unnecessary weight (ranging from just removing spare tires/loose crap in the back, to full on removal of seats)--more weight equals more demands on the tire, quicker for them to feel "greasy". Most passenger tires will run 40psi +/- 6psi, in my local climate, without running into an issue with feeling greasy on regular commuting. I run 34psi on performance summer tires, but that's for the marginal increase in sidewall stiffness, and so that my plus size (both in width and sidewall height) tires can soak up the pothole-ridden roads better. If the roads were better, I would run close to 38-40psi.
Long story short, I'm guessing that you're probably better served lowering your tire pressures on your entire fleet which is presently running on max psi. I suspect mileage decrease will be minimal, but acceleration (less psi = less weight), braking (more tire contact) and turning stability will all be noticeably improved.
What's everyone running for psi in these? I was at 44 but finding it a bit harsh. I just dropped to 36 psi. Havnt tried it out yet.
shop put mine at 42, too harsh for daily driving, dropped to 36.. rides much better, but gas mileage took a big hit.
Just put the first 880 miles on this old/new girl that I recently bought. Has 31" x 10.50 x 15" Cooper Discoverer AT3's. I'm sure they're pretty old but they're in great shape, have lotsa tread left and handle/ride very nice. When I loaded her up in Hell-A I stuffed about 800 pounds of crap in her and drove her to Ensenada to the new house. Then another 150 miles or so after she was empty. Ride felt a bit rough so I dropped the rears from 45 psi to 32, and the fronts from 48 to 34. Huge difference on the rougher city/dirt roads down here----but still handles great at 65 on the 'interstate'. I'm liking these shoes, but the next test is to drop the pressure down to 12 next week and see how she does in the softer sand I have to drive thru to get to the hard packed stuff along the high tide line. If y'all don't hear back from me next week it's 'cuz I'm probably still digging myself out of trouble......:cool:
image_3.jpg~original
image_2.jpg~original
image_1.jpg~original
image.jpg~original
4Runner4.jpg~original
Baja8.jpg~original
