Hi Everyone, After having put in JBA upper control arms, and redoing the suspension with Bilsten 2.3" springs in the rear, and 5100s up front with what I believe are FJ springs. From what I can tell using a tape measure this has lifted and leveled me a little over 2.25" all the way around. Reading some of the posts I felt optimistic I could get the Cooper ST-MAXXs in 255/80 r17s to fit...I was wrong. At first I thought they fit, then when I was turning the wheel they would bump the front edge of the UCA. As a backup plan I bought spacers. Put those on and am now clear of the UCA but am catching the rear of the fender flare and just grazing the body mount. Im not sure where to go from here. Im considering adding a 1" spacer on the rear and going up to the highest notch on the bilsteins up front which should give me about 3/4" more up front. However, not sure this will solve my problem or is needed. Need some suggestions on what will be the best solution here to get these to fit. Do I need to just find a place to do a body mount chop? Is it possible an alignment tech could push the wheels far enough forward? Im really at my wits end here and tired after 2 days of monkeying with this thing and am open to suggestions. Any help is greatly appreciated!:help:
