HiVel-JR
Falls said:Your headlights are that high with only a 1" diff. between front and rear lifts ?? Hopefully you can adjust them that far down .
Tires I personally would go with 265/70's , then you can atleast fit the spare in .
I dont understand that "preload" spacer , what does that mean , and are there other types. Dont all the spacers go on top of the coils ?
How did the install go ?
Dont forget to get an alignment.
Did you notice any difference in ride ? how about handling ? does it seem a little more tippy / unstable cornering.
My head lights were a little high before the lift, but I am not worried about the height right now. The install was not too bad, pretty darn easy if you have a little knowledge of vehicles. The instructions are right on. I am getting my alignment this afternoon, and as far as the ride, it is a little stiffer and feels a little top heavy, but it is not that noticeable. The cornering is fine, did not notice a difference when cornering. It did change the ride, but not much, it feels like the rear end wiggles a little more, but not that bad. I hope that makes sense. As far as the preload spacer for the 2inch, cornfed says leave the original rubber spacer off, (I think that is what you are referring to), because the 2 inch spacer is plastic. I saw a picture of Alexjet's 2 inch lift and he had left his rubber spacer off as well. (between the spring and the lift spacer) hope that makes sense too.
cheers
