Costco Gadget (Air Compressor - 12V)
BamaDrewski
I found this little air compressor (12V cigarette lighter powered) at Costco and even though it is not Hercules when it comes to filling up a tire, it works pretty well. I bought it for to satisfy that "just in case" hunger.....
Perhaps you could post some specs ?? And if you're really feeling productive the price. Yes, I'm too lazy to look it up.
Maybe compare it to the Hong Kong Freight model;
https://www.harborfreight.com/12v-100-psi-high-volume-air-compressor-69284.html
$34.99 100PSI high volume
Product Details:
This Bon-Aire 12 volt inflator plugs into your vehicle 12 volt power outlet to conveniently inflate vehicle tires, bike tires, sports equipment and more. The twin cylinder design delivers fast, powerful inflation that is smooth and virtually vibration free. It has a 150 PSI easy to read analog pressure gauge. The 15 foot 12 volt power cord and 48 inch air hose combine for 19 feet of total reach. The inflator has a built in carrying handle and comes with a durable carrying bag. Inflation accessories include: 15 amp fuse, 2 raft nozzles, Presta Valve adaptor and sports needle.
Features:
Plugs into vehicle 12 volt power outlet.
Twin cylinder pumping assembly.
150 PSI analog pressure gauge.
48 inch rubber air hose with Quick-Connect adaptor.
15 foot, 12 volt power cord.
Convenient carrying handle.
Durable carrying bag.
Weight: 5.18 lbs.
Dimensions: L 8.5” x W 3.625” x H 7”
I've got one of those, think I paid $40 or so. It's nothing mind-blowing, but it works well enough to air up at the end of the day.
All looks fine for emergency roadside type stuff...
This is a solid budget pump that should be considered.
https://www.amazon.com/gp/product/B005ASY23I/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
This or another higher air-flow pump is Really what we need at the end of the day after airing down. I can't stand taking 30-45 mins to air up 4 large volume tires, ugggg!
So compare the airflow ratings before you buy, if they don't list it, you know its low flow, it'll get to 150psi eventually. :cowboy:
That sucker runs at 20 amps though, I'm not sure the cig lighter circuit could handle it, I think it has a 15 amp fuse.
Yeah I saw that too (20amp draw) but it has gator clips so it connects directly to the battery. Cord and hose are 26' combined, should be enough to reach even the spare. Plus not many items on amazon get a combined 4/5 star rating of 94%! :cowboy:
I bought that pump just to have around for road side stuff and to move between cars, but for the trail, I have a Viair 400P that use for air up. The air volume / speed is dramatically improved.
I almost went with a 450 @ 100% duty cycle but the 400 was a higher volume pump, capable of inflating all 4 tires before the duty cycle limit so I didn't really see the point in caring about duty cycle, and in favor of higher speed fill.
I got the smittybilt 2780. Onsale for $79.99. Usually $99. Fills 33s from 15psi to 32psi in 4-5 min each tire. Even worked on some 35s. Runs on 14v when car is running. Nice carry bag also. Has a solid base and very good cooling fins so does not get hot.
I got this, it’s for my F250 that has 35s on it, but I burnt out my cheap one trying to air it up after I got a nail in the tire. I had a plug kit but that poor little compressor couldn’t keep up.. it was literally smoking and died a painful death.. this one is not cheap but like my buddy says.. “it only cost a little more to go first class”.
seltzernator
