Coverlay Installation for Cracked Dashboard (video)
OliviasDad
I purchased my 2004 4Runner back in June of last year and at the time was not aware of the dashboard recall. And I must admit, when I test drove my 4R, I did not notice the cracks in the dash because I wasn’t specifically looking for them (they were small hairline cracks, just above the gauges and steering column). Once I noticed the cracks however, I saw the info regarding the dashboard recall and even came across some paperwork from the previous owner regarding the recall (i.e., letter from Toyota), but it was already past the May 2017 deadline. After having the 4R for only a few weeks, I noticed new cracks forming (i.e., my parking lot for work is outside and in direct sunlight/heat). Here is what my dash looked like:
I talked with Toyota about getting a replacement, but basically got told that I would have to pay for it outright (~2k)…which was not going to happen, so I looked into options. I saw some folks who covered the dash with carpet/suede covers, but I did not care for this option. I also saw a product called a Dash Cap that looked nice, but I could not find a direct link for 2004 4runners. I then saw the Coverlay and thought that it might be a good solution. In doing some research on this forum and others, I only found a few mentions of the product and came across only one image (I even made a post asking about it, but got very little response). I read a handful of reviews including a couple from 4th generation 4R owners that seemed very happy with the results.
The Coverlay is not a cheap option per se, but it is cheaper (and less time consuming) than replacing the dashboard myself, so I decided to go ahead and order one last week. Prior to ordering my Coverlay however, I contacted Coverlay and asked for some free color samples because I wasn’t sure if my dash was black or a dark gray (mine sort of looks like charcoal). The free samples they send are on paper so matching isn't a perfect option but they will send you plastic versions for $4. Deciding that the black matched my dashboard the best, I ordered it through Rock Auto (roughly ~$155 shipped – I ordered a handful of other parts as well, so this is my best estimate, there is a 5% coupon code available as well).
Besides color differences, the 4runner Coverlay comes in two options (with and without speaker holes), my 4R does not have the speaker holes. Rock Auto shipped it quickly and it arrived within a few days and my first impression was good. The plastic molding is thicker than I expected and the color is very close to the original. It also conforms nicely to the old dash. Here is a short video of my pre-install:
Pre-Installation of Coverlay Dashboard
I plan to fully install it (glue it down) later this week when I get some time, will report back with additional pics/video of the final result.
So if you're tired of looking at the cracks in your dash and want a reasonably priced solution, the Coverlay may be a good option! I'll be sure to report back on any issues I note with installation and/or things I notice with it after it has been fully installed for a few weeks (i.e., creacking, etc.). Cheers!
That looks like a great solution honestly. I'll be bookmarking this should my dash start cracking.
Cheers!
If the instructions don't already say so, I reccommend scuffing up the surface of your original dash with sandpaper so there will be better adhesion. Looking forward to more pictures!
Light sanding is involved on both the dash and underside of the Coverlay per the instructions. Will make sure to post final results once I install it!
Final results
Installed the Coverlay and I'm very pleased with the results. Installation was fairly simple although you do need to prep the old dashboard (clean, sand, clean) and the Coverlay itself prior to applying the adhesive. The tricky part is getting some areas of the Coverlay to be pressed up against the old dash (I used books, weights, as well as some other options). Here are some images of the final result:
(sorry this is blurry, but it shows front windshield view)
If you weren't lucky enough to get your dash replaced through the recall notice and hate looking at cracks on your dashboard, then the Coverlay seems to be a good (and fairly low cost) solution. Cheers!
It really does look good! I know it has only been a couple of weeks but have you noticed any creaking or rattling?
Sorry I just saw this. There is some creaking, but I wouldn't say it is any more than what I noticed with the original dash. Ultimately depends on the roads that I'm driving (i.e., less noticeable on highways) and in my area they are terrible.
Good feedback. I was considering this but now I'm only considering this if my Dash starts creaking or gets to the point to where it looks so bad that the creaking is a better alternative then a disintegrating Dash.
I don't have any creaking and I don't really want to introduce any either.
Bummer.
Sent from my Pixel 2 XL using Tapatalk
How were you able to get it for $155 shipped? The cheapest I can get is $169 shipped from RockAuto with the 5% coupon.
Cost me ~130 after the 5% discount, then $26 to ship (MO). Shipping is probably the difference. It only took a day or two to get to me after I ordered.
Bummer.
Personal preference I guess. The creaking is minor and only noticeable on rough roads and when there is complete silence (i.e., no radio). Like I said, my old dash did the same thing at times. The cracks in my dash doubled in size in basically 8 months time, so it was only going to get worse with time. I personally prefer to not look at a cracked dash vs. some minor background noise on pothole roads. Best case scenario, get a new dash installed through the warranty, but this is a good option for those that missed out on the recall, like me.
I just noticed two small cracks on the driver side, under the vent. Unfortunately my warranty expired years ago. I do like the look of the Coverlay, but the price is way to high. If or when I do need a new Dashboard, Im just going to buy a Dash Cover Mat for $49.00 on Amazon.
https://www.amazon.com/Toyota-4Runn...75094&sr=8-3&keywords=toyota+4runner+dash+mat
I looked into the dashboard carpet options but ultimately didn’t care for how they look. The Coverlay covers the existing dash entirely and is not even noticeable. It took me a few months to justify the cost, but as my dash cracks began to spread and multiply, the cost became easier to swallow.
Update on the creaking: My Coverlay was rubbing on the passenger side in the corner where the upper windshield trim meets the dash. I pulled the trim off and added some silicone where the two meet and now there is no creaking or rubbing sounds on rough roads. So if you install one, look at these trim pieces as sources for rubbing. An easy fix.
Great news! This is back on my list of things to do ... someday...
My dash looks like the San Andreas fault. Definitely taking this into consideration after seeing your pics and vids.
Thank you!
DJNutshell
