CRank pully!
1. Walk it off by using two pry bars behind it.
2. Rubber hammer.
3. Harmonic balancer removal tool - probably the best way to go.
4. Jaw puller.
i got it thank guys, i tryed the pry bars didnt work try to walk it off. rented a puller!
Be careful with a jaw puller. The HB is a pulley sandwich, with the outer part (that the jaw pulls on) separated from the inner part (that is stuck to the shaft) by a rubber cushion layer. A jaw puller will tend to just separate the two halves if it is really stuck. Result: dead HB. Use the kind with bolts that thread into the inner core. Like this one:
http://www.harborfreight.com/bolt-type-wheel-puller-set-69889.html
Not just for you, but anyone who reads the thread. I do not recommend jaw puller for this.
2. Rubber hammer.
4. Jaw puller.
[MENTION=69868]LittleCaesar[/MENTION] hit it on the head. About 97% of the time, you can use 2 pry bars behind it and walk it off. Consider using some rust penetrant.
Bolt-Type Wheel Puller Set
thats the one i used, the pully just needed a little help moving n then came right off.
i tryed to walk it off afte rsoaking for about 30 mins, but i felt like i was putting to much force on the edge of the pully with the bars. rented a puller. 2 mins it was off smooth as silk.
