Crank shaft pulley question- not bolt
jkfuel
Just got the bolt of the crankshaft for doing the timing belt repair. How do I remove the pulley? I've tried a pulley puller and a jaw puller but they do not work. Help!
It *should* just slide right off once the bolt is out. I tapped mine with a rubber hammer a few times and it slid right off.
But before that, I loosely threaded the bolt back in to avoid dropping the pulley.
I needed to thread bolts into the 96 and use my puller. The woodruff key *****ed up. But it also had rust on the crank. It was on real good.
Glad you got it! When I was changing the TB I wrapped the old belt around the pulley before hitting it just to protect it a bit more. Also PB blaster...
