reluctant1
I had blown head gaskets on a 3.4L '02. After removing heads and having them machined and valves adjusted I decided to remove the block, hone the cylinders and check the rings. Although the initial turn of the crank was difficult prior to removing the heads, it was able to turn with a moderate amount of effort in subsequent turns. However, a few days after removing the heads, I tried to rotate the crank to gain access to the torque converter bolts to remove the block and the crank would not turn. Much more torque was applied than the initial turn and it would not budge. The transmission is in neutral with parking brake applied. Disengaging the parking brake allows the vehicle to easily roll. The oil pan has been removed, PB Blaster applied to cylinders and connecting rods, all to no avail. Is there anything that could have "locked" the torque converter preventing it from turning?
