Crawford Eco Block
C. OEM safety margin is too wide for any and every condition on this planet, the moon and even mars, we could trim it down a bit and not suffer any reliability issue :D
This is our concept as well, during the testing phase of development we found an optimal thickness for maximum power. This is what we used on the race cars for a full season but our production units are close to 20% smaller to give us a safety factor / cushion.
We have tossed around the idea of making a "race" version that is thicker and maxes out the power potential :)
I posted my full tank results over there.
I ended up running 381 miles on that tank. I filled up and this was the amount of fuel.
I have calibrated my Ultra Gauge multi-times since it was installed and I always double check the math. I have no dog in the fight, mine cost me $45.45 shipped to my door. I plan on ordering one for both 3.4l 4Runners and my wife's 2003 4.7l V8 4Runner.
My mileage on the tank prior to the install was in the high 18s, I have never gotten over 20.4 on any tank since I bought the Tacoma.
Damn...I am more interested in $2.60/gallon.
Thanks for the data Darryle
I really need this.........:rofl:
I get this kind of mileage if i'm not careful on just city driving. Let me put it this way, if I have done nothing but city driving for 200 miles, I'm happy if i get 13.5MPG on the dash.
[MENTION=121742]Quirt[/MENTION] , any way that we can get the actual air fuel ratio before and after this spacer is installed into the vehicle from you? I know you will need a test subject, but some people are willing to give it a shot? The reason I ask is because even though it may be minimal change in some vehicles, it would be more interesting figuring out what it does to this vehicle.
I stated earlier that on my 06 Tacoma at WOT it it read 10:1, so I'm wondering where the air fuel ratio will be after the spacer for the Tacoma and 4Runner if its not to much to ask.
It is not a problem to ask for this data and I will be happy to supply it to you. We have two different customers that are supposed to come by this week for some dyno testing so it should be soon.
I have seen a almost a full point change in AFR so if you are currently getting 10:1 then I expect to see 11:1 after installing our EB. You can quote me on this after the dyno tests ;)
Not here, at least not in this area we are back up to roughly $3.60/gal.
I would like this post, but nothing to like about $3.60/gal gas...
Yes, CA is $1-1.50 more than most of the rest of the country. :mmph:
Maybe I need to spend half a tank of gas on this thingy so I can save gas and increase HP to 400.
I have a deal for you... buy one for your truck and we will give you another free one for your Lexus ;)
So If I buy one for my T4R, could I also receive one for a Scion TC 6.0?
I made that offer because I want to get some product on other types of vehicles.
We have lots on the tC platform at the moment... but good karma is good karma so why not :)
Quirt... Try to get a discount for the t4r crowd. I'd be more that happy to give it a try.
Ok, just asked for a code that will last through the end of the month. It will be the same discount as we offered on TW.
[MENTION=121742]Quirt[/MENTION],
Asking for the discount code that will last thru the end of the month please.
Will it also apply to the Q2 as well?
I couldn’t stay away!
Many claims have been made and a lot of educating (myself included) has gone on in this specific thread. I think that is great. Personally this product is still not for me, and Quirt can take this feedback or leave it but the following is my attempt to explain my continued skepticism. Yes some may believe that my standard of proof is high and that is okay with me. All and all though I will say that Quirt has been very professional and I commend him for sticking to his guns.
Directly from the Crawford Performance website:
1) As explained, and forgive me if I have this wrong, the device repositions the MAF sensor to a different flow stream within the inlet. This tricks the ECU into believing there is less air flow and trims fuel and possibly other engine systems to run at a different open loop map.
Having never seen the Toyota source maps, I do not know for certain that the open loop map is not trimmed by the closed loop map trim. It would seem simple enough for the ECU to learn what the closed loop offsets are and apply them to the open loop to hit the desired set point but that's just me. Let’s presume that this isn’t the case and that the engine system will function as described previously.
Post #65 by Quirt
Knowing that no optimization has been done is a bit scary considering I for one am presuming that Toyota did optimize their system. But let’s presume that this device does ‘fix’ a Toyota optimization failure.
Steve W. posted the following on a different board Post #7 on 6-15-2006
Pickler posted the following on a different board on 01-23-2015
Both of these show where peak power vs. peak economy occur. Perhaps Toyota is unaware of this optimization. Additionally in the second graph you will notice the increase in EGT and cylinder head temp curves which may be of interest to reliability for some.
Flow velocity profiles can be found here and knowing where this sensor is baselined on a profile and being repositioned to could help you improve the product. I really have to question what data or math drove the decision process mentioned above.
2) Air filters vs dyno (skip to 1:55)
30 hp on an air filter. If this is true, we should all go change our filters! Just a friendly reminder for doing general maintenance can provide a really good boost to your vehicle all around :)
30 hp / (400 hp?) ~ 8%... where did the 8% gain claim originate for the eco block? The charts posted thus far show 60 to 63 hp (5%) and 190 to 200 hp (5%).
Single dyno runs have been a long standing tradition of the aftermarket trade. I admit that I have never put my vehicle on a dyno. There are many variables in play all of which can contribute to showing gains or a lack thereof. For example, the baseline could be a well warmed up engine and transmission with the AC blasting and a dirty air filter while the modified run is a cold engine and transmission with all accessories off and a brand new air filter (OEM or other) with the ECU recently reset. I asked in another thread just the other day if the person had recorded any extra vehicle sensor temps during their dyno runs and if they had a dyno calibration spec sheet. More data is better and independent 3rd parties are best :)
Here’s a video showing back to back runs without changing hardware (6:45 ~ 210.7 hp, 7:00 ~ 204.3 hp = 3% variation) Actually that video is rather interesting with respect to dynos and "snake oil". I could even tell you that the reason the aftermarket filters used didn’t increase power was because they didn’t allow time for the ECU to reset… almost as if one wants to see positive results, one sees positive results and if one wants to see negative results, one sees negative results when it comes to pseudo science type stuff.
If you want to optimize the spacer for power and have access to a dyno, why not record MAF, TPS, O2, Fuel injector duration, pressure… to fine tune the product?
3) I had a section on patents here but someone else took care of that… the only other speculation I had was perhaps the patent/pending wasn’t in the US but I guess we’ll never know especially if it’s not marked on the packaging or part.
4) There is no statement on the website that this is an ‘off-road’, non ‘street legal’ device. If this device is modifying emissions, efficiencies, and power output as claimed, then it should be CARB approved seeing as how this is being sold out of a California facility without restriction (Escondido Toyota).
Blue color adds 20 hp ;)
I look forward to everyones results.
Trust but verify and best of luck to you all.
It sounds like there may be a trade-off between power/economy gains and reliability/working in every environment. So it's not something that you can optimize, but a trade-off between performance gain and risk. A 5mm spacer gives a modest performance gain with no detrimental effects noticed so far, or low risk. An 8mm or 10mm spacer may give you more gain, but there's more risk of something going wrong. People with very low tolerance for risk should keep it stock. People with more tolerance for risk might try this if there is some evidence that it provides some benefit. People with a high tolerance for risk might try this just based on the manufacturer's claims, without a whole lot of additional evidence.
People often report increased mileage after changing their air filter, but that makes no sense except at WOT because the throttle is the biggest restriction in the system. A dirty air filter is the same as the throttle being a little less open.
People often report increased mileage after cleaning their MAF sensor, but that makes no sense either because a clean sensor will make the ECU think there's more airflow than before (assuming dirt on the sensor insulates it and keeps it hotter), but this device is all about making the ECU think there's less airflow.
People often claim that the V8 4runner gets about the same mileage as the 4th gen V6, but if you actually look at the numbers reported on the forums you will see that the difference is roughly in line with the difference in EPA estimates.
If this device increases power, I would expect people to report lower mileage because they spend more time at WOT trying it out! :)
There's a lot of variance in mileage numbers, even without changing anything about the vehicle. See my Fuelly profile, for example. http://www.fuelly.com/car/toyota/4runner/2007/m85476585/314608/fuelchart The only change I've made that I can think of is whether the ski box is on the roof or not, but even that doesn't make much of a consistent difference in the results.
My point is, anecdotal reports of fuel economy improvements are unreliable. There may be some placebo effect or confirmation bias.
Mike Sargent
