Creaking noise on driver side rear
JeratBP
Member
Has anyone else had creaking sounds from the rear driver side? It's usually noticed when taking turns. I removed the jack and stuff from the rear compartment. The small compartment over the wheel only has a t-shirt in it. The rear shelf is locked in place.
It's been going on for a while now. Also, I replaced my XREAS system last weekend.
Any suggestions?
I'm fairly certain it's inside the vehicle. If it were the bushings, it could be the sway bar link bushings, since the shocks are new.
If the sound is coming from the inside should be easy to isolate, have someone drive it for you while you get back there and isolate where it's coming from, don't know any other advice to give you but to get close and personal with the sound!!
H.Sikina
