Creating a softer ride for a 1998 4runner
kingbiscuit
I just purchased a 1998 4runner 4x4 3.4L and I like it but it would be nice if the ride was a little softer. This is my first Suv/truck, and in comparison to others I have driven it is already much better ride. I would just like to feel the bumps a little less on the road. Is this even possible? I am guessing that trucks have stiff suspension to avoid bottoming out on trails. I could be wrong on that. But only a small percent of my time is going to be 4x4ing mostly I will just be road driving. I wouldn't mind being a little more careful on 4x4ing if it meant I could have a nicer ride in the city.
If I can't change it, so be it, I will still love my new 4runner.
Monroe Sensatrac's seem to be a popular choice when looking for mostly on-road shocks. Also, Tokico Trekmaster's aren't bad, either.
Most likely, your shocks are already shot on your 98, so it'd be a good time to change it out, anyway.
check out your rear stance/springs
It is easy enough to have the shocks changed out all the way around-but I would encourage you to check out your rear springs and the way the vehicle sits-particulary in reference to the 'sagging rear'.
I needed new shocks on my 99 shortly after I bought it one year ago and got the regular Bilsteins for the vehicle. They ride just fine but it is still a firm ride no doubt about it.
Now sure enough my rear springs have started to sag-and the vehicle has a slight droop to the rear-the spacing between top of the tire and wheel well is decreased in the back as compared to the fronts. A number of makers offer a taller or stiffer spring-and I have not read one bad thing about the OLD MAN EMU (OME)
package for our 3rd generation Runners. As I understand it you will get a very slight lift-2" or less -and their package includes springs and shocks for extended articulation/travel. Performance Products also offers a spring and shock kit.
Re: check out your rear stance/springs
Is the "sagging rear" a notorious problem? I am pretty sure the girl I bought from did not do any 4wheeling with it. She actually told me she never took it out, so hopefully that is true, so I think the springs should still be good.
common problem
yes this is a fairly consistent complaint amongst 4Runner owners
nothing to do with off roading-just over time the springs begin to sag.
Just FYI, your 98 *should* be under recall for the rear springs. I know when I had my 98, they switched out the rear springs when I was getting a seal replaced. This was last year.
Check with your local dealership. You will probably be getting brand new springs in the back.
Re: common problem
When you say "sag" do you mean you can visually see it sagging when it is parked, or when you hit bumps the rear end dips excessively?
Re: Re: common problem
You can visually see it sag. Much like this 4Runner:
visual difference while parked
thanks pnut
good visual
I do believe there is a Technical Service Bulletin (TSB) regarding the springs-meaning Toyota acknowledged the problem and would rectify it.
Thanks for the visual.
Mine doesn't look like that. The previous owner bought it from a dealer in 2001, I wonder if they fixed it at that point in time. I willl have to see when the recall happened
TerryNap61
