Crush washer for oil drain plug
druuu88
I recently changed my oil and filter....and the next day noticed an oil spot under the front of the car. I double checked the filter tightness and sprayed/cleaned off the bottom of the car to be sure it wasnt old oil dripping down. I stupidly forgot about the crush washer on the oil drain plug....it either needs to be flipped (only once of course) or replaced with every oil change. I thought i would share my stupid mistake with all of you so no one else here would run into the same problem!!!
I feel your pain...Just ran mine the 3000 mile interview with a constant drip. Purchased my truck used with 28,000 miles from an Infinity dealership and made them change the oil just before I took delivery (The owner had put 2,000 miles on my truck...owner of an Infinity dealership driving a Toyota, HeHe) Drove the first 3,000 miles with no drip...Changed the oil myself and no washer was on the plug so I didn't think to much about it. I'm absolutely positive it had no washer as I as very careful upon removal. How they kept it from leaking with no washer is beyond me.
I kept a good eye on the level for the 3,000 miles and it only lost 1/2 Qt. with no crush washer. Did some searching on the Boards and found out this is a Toyota Product and They intend you change it everytime you change the oil. Don't go to the Stealership to buy one tho since from what I understand they get around $1.00 apiece. I found a Web Site and got mine around .16 a piece. I ended up buying 50 at one time to max out my shipping charges so I'm set for a while.
This washer is some sort of paper almost like gasket material. I think the price went up to about .20 a piece plus shippinng but for that and piece of mind I'm changing mine at every change. Just changed oil last weekend and all drips are gone.
Hope this helps you and everybody just getting ready for the first oil change.
I'm going on 5 years with my original washer.....do my own oil changes. I do make sure the surfaces are clean and dry when putting the bolt/washer back in.
What year is your Truck?
2001
I should replace mine soon. I would not call it a crush washer either. And now that I think about it ...it has a rubber coating on one side. ?
