Curb weight, payload, etc question...
mainerunr
OK, so something doesn't add up to me here...
Toyota lists curb weight for a TRD ORP at 4750 and GVWR at 6300 so how is payload only ~880? What am I missing here?
I don't think you're missing anything. All models with the locking rear differential are rated lower than the ones without it. IIRC my SR5 is rated just a tad over 1000 lbs payload.
Sent from my SM-G998U using Tapatalk
A payload of around 1000# seems really low relative to GVWR-Curb Weight.
Payload should be GVWR- Curb Weight so it seems like it should be ~1500lb.
If the rear locker reduces it that much, the GVWR they note should be reduced as well.
Has anyone put one of these on a scale stock just to see what it actually weighs (full tank of gas)?
Guess my ex-wife's Tacoma's payload rating makes more sense now, that was under 1000# but she's got a TRD Off Road, minivans have more payload.
I'm probably a little spoiled, my F150 has over 1800lb payload and it doesn't even have the payload package or max tow...
Just looked at the manual - 1165 lbs, 835lbs for those with locking diff. Guessing the lower number accounts for when the differential is actually locked - if unlocked it can likely handle what the open is rated for easily.
It's been my theory that this was Toyota's way of limiting the potential torque load on a single axle shaft when the diff is locked.
If operating with the diff open, I'd have no concerns about using the payload figure for open-diff 4Runners.
The problem I have is wrapping my head around why the payload in either case does not match GVWR-curb weight. That is how everyone else does it, Toyota seems to just pull numbers out of nowhere...
seltzernator
