Custom-Fit LED headlight Bulbs w/Dust Cover for 2014-2020 4Runner
lasfit
official vendor
attachment.php
attachment.php
Why did Lasfit develop custom-fit LED bulbs for 4Runner?
The projectors used on the 2014-2020 4Runner headlights are different from other vehicles. The bulbs are inserted from the side instead of the rear. It is hard to install the regular centric-type heatsink LED bulbs in the 4Runner because a metal bracket on the inside prevents the bulb from fitting correctly.
attachment.php
Some fanless LED bulbs might fit the headlights, but they are not bright because it is impossible to put high-power LED chips on fanless bulbs. LED chip generates heat, especially in sealed headlight housing, if LED bulbs without a fan will not last long. Thus, we developed some unique offset-heatsink custom-fit LED bulbs with dust covers for the 4Runner.
What's the custom-Fit LED bulb?
1. Off-center design perfectly fits on OEM headlight socket. Easy installation
attachment.php
2. The extended dust cover prevents dust and water get into the headlight housing.
attachment.php
3. Unique Dual-Cooling fan for high-efficient heat dissipation and prolongs the life of the bulbs.
Super heat conduction & heat-dissipation system
attachment.php
4. 50W, 5000LM per bulb, extreme brightness with focused lighting beam, sharp cut-off pattern.
attachment.php
[/CENTER]
Click Here to Check out the Custom-Fit LED Headlight Bulbs w/Dust Cover for 2014-2020 4Runner
If you have any questions about these LED bulbs, please don't hesitate to post, PM, or contact us by email ([email protected])​
20%OFF - Pro LED headlight bulbs, backup lights and turn signal lights.
Hey guys,
We're excited to tell you that we offer a big discount for members in this forum as a return to your support.
1. Pro Series custom-fit H11 LED headlight bulbs: 20% off / 5 promo codes available
2. LED backup lights: 20% off / 5 promo codes available
3. Front turn signal lights: 20% off / 5 promo codes available
4. Rear turn signal lights: 20% off / 5 promo codes available
Custom H11 LED Bulbs For 4Runner|Lasfit
● Everyone could choose two of above LED lights.
● Email us to tell which LED lights you would like to get and the year and the trim of your 4Runner, and we'll send you the discount code.
● Email: [email protected]
LED output lighting pattern VS OEM halogen lighting pattern
We have tested our Pro-Series H11 LED bulbs on 4Runner headlights again and again when we were developing this custom-fit LED kit until the output beam pattern is almost the same as the stock halogen beam pattern. Cleat cut-off, much brighter!
attachment.php
attachment.php
These aren’t ordinary LEDs , these LED headlight bulbs have an offset heat sink and they come with a dust cap that has a built in fan. The fog light bulbs are switchback, freely switch between two colors: 6000k white and 3000k amber!
attachment.php
Thanks to @Kc for these beautiful pics and his comment for our Pro H11 LED bulbs.
"Awesome kit, easy to install! I absolutely love how it came with a great fitment on the custom dust caps with this kit. A mini fan is build in also from preventing overheating."
attachment.php
attachment.php
A huge thanks to @S.P. for sharing these amazing pictures!
He has Lasfit Pro series H11 LED bulbs with dust cover and dual-cooling fan (# Pro-T4-H11) installed on his 2016 4Runner SR5 premium.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Have you ever had the same situation that you purchased the regular H11 LED bulbs, but you can't install them on the headlight socket?
For most vehicles, the socket is in the center of headlight housing, it's easy to install LED bulb on it. But for 4Runner headlight housing, the socket is off-center and there is the bracket to block the LED bulb to lock in place.
Lasfit Pro series H11 LED bulbs(#Pro-T4-H11) are specially made for 4Runner headlight, the accurate socket angle and off-center heat sink design are based on the OEM housing socket for a perfect beam pattern and easy installation.
attachment.php
attachment.php
attachment.php
attachment.php
ian2328
