Custom Garmin GPS mount
closer
closer
Re: mine
tigerspy said:
here is what I did with my garmin nuvi mount.... i Know i have a nav with my 4runner already..but the nuvi has custom POIs and I've got downloaded all the speed traps and red light cameras...also i got my nuvi before i got my 4 runner and it has more up to date maps up to 2008
dude, looks pretty sweet.
i also have a nuvi, do you mind me asking where you got the downloads?
downloads
for the most up-to-date maps you can go to the garmin website....but for POIs the best free place is www.poi-factory.com you can get justs about anything...and the best part is the speed traps and red light cameras....also you can download different vehicles...someone even has a post of a 4runner image
jwa898 said:
Where did you get that bean-bag mount, and how does it work?
I got mine off Amazon for about the same price they have it listed now. It's about $13-14 less than retail. The underside of the beanbag has a grippy material so it won't slide around or off the dash. It works great and I'd recommend it (if you don't want to leave the suction mount on the windshield possibly indicating to thieves the nav might be hidden in the car or if your state, like CA, doesn't allow mounting anything on the windshield).
Thank you Uneek for answering it for me!!
jwa898 ... Both Uneek's pop & I both got it off Amazon.
jwa898 said:
Is there a way to plug the Nuvi in so it charges while its on the bean bag stand?
Absolutely!!
No problem at all...I've used it many times while it's on the bean bag stand.
It's inexpensive on Amazon...if you can't wait, Best Buy has it for $42.
[click here] Nav Mat
Not sure about the other models. On the 660, the cigarette lighter cord plugs into the base that clips on the back under the antenna. That clip base pops off of the windshield suction mount and is transferred to the bean bag. The supplied cigarette charger does not use the mini-USB plug that the AC adapter uses.
Well, I borrowed from the original posters idea and made my own. Went to the hardware store and bought an aluminum door kick panel for 7.00, then went to ebay and ordered a cheap vent mount to get the "ball". I didn't want to cut my original. I paid 5.00 for the vent mount and cut the ball off using a hack saw. I then cut the aluminum plate with a saber saw with a metal blade and shaped it using a vise and rubber hammer and then painted it. It could use some sanding, and another coat of paint, but it will do for now. Here is how it turned out.
garminmount001.jpg~original
garminmount003.jpg~original
garminmount005.jpg~original
garminmount006.jpg~original
garminmount008.jpg~original
garminmount011.jpg~original
Looks really slick, congrats.
What does it look like with the cord attached? I have the cord running everywhere. Can you post a pic with the cord?
Thanks again for the idea
I have another 12v outlet that I installed specifically for the garmin. I borrowed that idea from another poster here on this site as well. But I basically used cable routing stickys that you can buy from home depot and then used automotive two sided tape, because it's stronger to stick them to the dash. I only use my garmin about once a year on trips, so this works fine for me.
garminmount012.jpg~original
garminmount013.jpg~original
garminmount014.jpg~original
workingwheelswnc
