Cv axle play
chris.andros.18
Asking if someone with a 4x4 3rd gen could get under there truck and tell me if there is any up and down play in the cv axle where it goes into the diff if so how much because min has about 1/8th of an inch up and down play if not just a little more and it is leaking around the outer diff seal just trying to find out if I need to rebuild the diff or just replace the seal
Sounds like a seal...but to my recollection the CV axles shouldnt have play.
I have about that much in mine. I noticed after I used Napa cv's. I also had in and out play and a leak. I changed the seals and left them out about 1/8" to account for the in/out play and all is well. Still slight up down but no in out and no leaks.
Ok good to know I just replaced the seal today so we will see if that solved the problem I notice a slight more amount of play up and down on the driver than the passenger. Wbu
Hey sorry to bump this old thread but my napa cv axle is having like an 1/8th inch of in and out play in the diff. I just put it in and the one i took out didnt have play, u think its a seal issue??
Seal have nothing to do with in and out play. Did you remove the OEM? There should be a small play as the only retaining part is a metal clip which usually have a slight play.
