CV Axle Replacement
captwalker87
How difficult is it to replace the CV Axles on a 93 V6 4wd? are there simplified instructions somewhere besides in haynes?
It is fairly simple to replace the CV joints. You can buy the whole reconditioned unit so you do not have to rebuild. I have a link somewhere for a write-up but I cannot find it right now--not on my computer. I will try to find it tomorrow for you.
They can be a pain to replace it depends on the vehicle. Some vehicles that I wont name (cough*volkswagon*cough) use hex head bolts, and i mean 12 or so of them all around the half shaft to hold it into the the transaxle, or in this case the just an axle. Usually you have to pop out the tie rod end to be able to swing the knucle around far enough to slip the old shaft out and get the new one in. The guide will tell you more or the fine details, mostly because i have yet to replace mine (judging by the new vibration in 4wd i think its time) but that should give u a general idea
cv axle replacement
I need some tips replacing cv axle, have not tore into it yet. I have done similar jobs on Hondas etc... does'nt look too difficult, do I need to remove a arm assembly to drop low enough to remove it?
'94 sr5 22re
ian2328
