CV Axles/Boots
Azwelder
Both my outer CV boots have worked themselves off the joint. They do not appear to be torn but the straps are MIA. I hear no clunking or grinding when turning in forward or reverse gears. Do I need to remove the axle shafts to clean/repack with grease/re-strap or is this something that can be addressed while on the truck?
I suppose you could repack them and replace the straps while they're on the truck, but I honestly think it'd be less effort to pull them first, instead of trying to work around the shocks and a-arms. You'd certainly be able to get more of the old dirty grease out if you had them on your bench.
Yeah I agree with kid. Even though its not the most fun I have had working on vehicles, removing the axles to replace the grease would definitely be easier. I bought my cv boots at Napa and they have been really good thus far. Good luck!
Are your other boots ripped or they just fell off?
I vote new straps and grease and be done with it. Ive had sticks push mine off, and fixed them on the trail with a large ziptie.. that was 3 years ago and it still going fine.
Its easier to replace the whole CV shaft than replace a boot...
Upon closer inspection, I have small tears in the passenger side boots only, driver side is good but showing some dry rot. I bought boots from Napa but like you said, it will probably be easier to just replace the entire axle shaft instead of messing with the boots. I can get a new axle for $62 where as the boots cost me $35. I may keep the boots and rebuild my old axle for a spare.
This is a good idea, but don't buy those cheap remanned shafts. Get new NAPA or Toyota shafts, or order new shafts from CVJ. The cheaps are ok for a street rig, but will not hold up to wheeling.
All replacement parts to this point have been NAPA parts. Would you not recommend their reman shafts either? Their new shafts are $130. Their reman is $52 plus $11 core.
I'm still on my original CVs so I don't speak from personal experience, but I'm pretty sure that every busted CV I've seen so far on other rigs has been a reman.
The reman has a lifetime warranty, doesn't it? You can always go that way if you don't mind changing a CV, I've pulled mine a couple times now and it's not that hard once you get it down. But I'd still rather pay the extra for the more reliable part.
I buy the new GSP shafts from Advanced Auto. So far the one I have in has stood up to some fairly gnarly abuse and it only cost $69.99 vs their reman for $59.99. I have another new one to replace my other original shaft on the passenger side. The GSP have a life time warranty and I did call that in on one so far due to the seal to the steering knuckle not seating right (probably my fault). Advanced swapped it out for a new one, no questions asked.
Whatever you choose, don't buy unless new and with a lifetime warranty. The boot kits seem way over priced when you compare them to just buying a new axle.
Clocktower07
