Damnit! Rear defogger
mavrick1903
Ok, so I’m looking through fuses for an answer to the code problems I’ve got, now the rear defogger isn’t working and the rear hatch window won’t go down with the key. Only the switch on the dash. The door locks work with the rear key though.
Where do I look next? I’ve pulled ALL the fuses and checked them. And I believe they’re in the right spots, both cabin and engine boxes.
Help?
Using the switch on the dash and the key in the "run" position, roll the window all the way down without stopping, then all the way up again.
Now try the defogger, rear wiper, and key switch, then let us know what happened.
If you disconnected the battery during your troubleshooting, then the rear window has to re-learn the up and down positions. If your rear wiper doesn't work right now, then it's a good indication that's what happened.
Of course, if your codes had something to do with the body control module, then I'd say you found your original problem.
Ok, re-initializing the window took care of the button and lock. Defogger is still not working. Looking for further input.
