Dash lights & Fuel Gage don't work-88
NCFJ
The dash lights and fuel gauge do not work on my 88, checked the fuses and all seems good. This common, happen to anyone else? I am thinking they may be related.
The backlighting uses the TAIL fuse, the gauges use the ENGINE fuse, so it's unlikely they're related.
Could be a bad/loose connection on the cluster, bad fuel gauge sender or damaged wiring at the tank, bad bulbs in the cluster...
I just fixed the lights in my dash in my '85 SR5 ...all bulbs were good , fuses ect.Upon inspecting the circuit Strips on the back of the Instrument Housing for Continuity I found 2 Breaks in the Copper Stripping.
To fix I.....T Tapped the Proper lead Off the Harness with a Small 18= 20 Ga.Wire & Stripped the other end Bare & Placed it under the next Bulb in the Line then twisted back in the bulb completing the Broken Circuit .
As far as the gauge you should be able to Ground it & make it move then go from there .
Thanks guys, I am going to start digging into it this weekend. I wanted to see if there was some sort of common issue that happens often prior to taking the dash apart.
My 87's fuel gauge only worked for the first gallon or so. As mentioned, check the sender in the tank. Mine ended up having most of the coils broken. Found a junkyard one and soldered the 'new' coil assembly to the old sending unit and voila, it works again.
