Dash rattle
gloch
Member
Maybe because my other car is a Lexus, the rattles in my '03 drive me a little crazy. Particularly the dash. Has anyone found ways to reduce rattles in the 4th gen?
do you have a center speaker? if so pop off the grill and you may find a circular piece has come loose, glue it back on and put the cover back.
careful with the grill, its a bit fragile, if you have a retainer clip removal tool I would recommend using that at the front of the grill to pop it up.
Good call. I will check it, although my grill is already broken. The main thing I notice is if I hold pressure on the dash, it stops rattling. Maybe this will help.
Must be something loose, maybe someone was in it and broke/lost a clip. My 20 year old truck has no rattles unless a loose tool is bouncing around in the back.
