Dash Speaker Question - 2019 TRD Pro w/ JBL
fx3s
I am replacing the stock tweeters w/ 3.5" since one of my tweeters are blown.
I have looked through all of the write ups and still have a question since my wiring seems a bit different (see pictures).
Goes to Tweeter
Yellow = +
Purple = -
Goes to Front Door
Green = +
Black = -
I have a capacitor on the positive lead for the wire that goes to the front door (green).
How should this be wired? Do I cutoff the green wire w/ capacitor since it's jumpered anyway? And cut the black? Not the jumpers.
I ended up wiring it purple and black together for -
and capped the green. then i soldered the bass blocker inline w/ the yellow wire.
see pictures of the wiring harness to speaker.
Goes to Tweeter
Yellow = +
Purple = -
Goes to Front Door
Green = +
Black = -
Why not get OEM Audio Plus speakers? (4runner - OEM Audio Plus)
They are plug and play, i.e. no wiring modifications needed.
I have a setup in mind for my 4runner that includes all JL Audio.
Always liked the brand/quality so oemaudio+ never really crossed my mind.
I could have bought the wiring harness from taco tunes and a 3d printed mount, to make it plug and play also but timing played a role...need the highs for work calls.
might change out the 3.5's with tweeters once the components come in.
Sent from my Pixel XL using Tapatalk
I just installed some JBL 329s in the dash and if you look at the connector coming from the amp, it only has 2 wires, one + and one -. The jumper wire you see along with the 2 wires coming out to the speaker has one set for the mid, and one set with an inline capacitor for the tweeter. You need just the 2 for the mid.
I initially installed the capacitor that JBL provided, but the sound was very quiet and it made a popping noise on startup. I removed the capacitor and the volume increased, the pop went away, and no distortion at Max volume (I listen to gangster rap).
I didn’t want to destroy my factory speakers, so I used the Taco Tunes harness (they do not have a JBL specific harness listed for the 4Runmer). 3D printed the brackets (thank you member on this site that posted the STL files!) and reused the factory bolts.
I did this mod, because I have blown the dash speakers 2x under warranty, fried the amp, and blew the subwoofer. This JBL system has done pretty horrible. Now that I am out of warranty (still only 29k miles on it), I have no choice but to upgrade to prevent a gap in music while I drive. So, I am in the process of full upgrade.
I was going to start a new thread but 15 posts is a lot!
Initially I joined the 2 + with the oem capacitor to the speaker but it was quiet as you mentioned. After that I decided to just cap the green wire (+) and us the yellow (+) to the dash speaker ...now dash and door work work fine.
I'm not happy my speakers blew, but am excited about the speakers I'm putting in.
Keep us updated on the progress!
DID you end up using the capacitor I'm confused, where in Northern NJ are you maybe you can help me do this I would pay you in beer??
Feel free to PM me ...
