Daystar 2.5/1.5 Alignment Specs?
salong53
I recently installed my Daystar 2.5/1.5 lift and I'm taking my 4Runner to get it aligned tomorrow. I've read quite a bit about alignment specs on different threads, but I'm looking to consolidate info and get suggestions. Here's what I think they should shoot for.
Camber: -0.1
Caster: 3.0 or as close as possible to that number (factory UCAs)
Toe In: .05
SAI: 12
From what I can gather these are pretty close to the factory specs.
How realistic is it that they can get near this with the lift?
Which of these measurements will be thrown off the most with factory UCAs?
Which of these measurements should I be a stickler about and which ones are not as important to driveability?
With something as small as a 2.5/1.5 you really don't need to worry about it. I don't think a single person on here has had trouble with alignment after a daystar lift. Mine was just fine even after the daystar and fj spring. Shop had no problem getting it in spec.
H.Sikina
