Daystar Kit
Hayden_
So I need some help. Basically I'm on amazon and was about to order a 2" leveling kit from daystar (the comfort one) and It said that it wouldnt fit on my 07 4runner so before i make a final purchase could someone copy and paste the link of a 2" leveling kit that they found cause I obviously dont want to buy it if it doesn't fit although i feel amazon is wrong...
this is the one i found.
Amazon.com: Daystar KC09101BK Comfort Ride 2" Leveling Front Coil Spring Spacer Kit - 2 Piece: Automotive
That kit appears to work with another truck.
You want one of these:
I have a 2wd 07 haha but I'm just looking for a 2" in the front which I'm guessing they don't have or make? So what're some other options I have for a leveling kit?
Get the Daystar Budget Boost. It is listed as 1", but it actually lifts 2". The part number is KT09117BK. If you'll search for that, the correct part should come up.
KT09115BK this is the kit for front and back that you need.
I have a different kit on mine with 2 spacers in the front, one on the strut tower and another preloading the spring. I cant find the part for this kit though. However, if you dont own spring compressors and have never worked on suspensions components before(guessing no since you're 16 sorry) the part# i listed for you above will be much easier to install. Could do it in 30 minutes.
Just to be clear.....Daystar offers two "leveling" kits for the 4runner. The first is the Budget Boost, it lifts the front ~2". The second is the 2.5/1.5 kit, this lifts the front 2.5" and the rear 1.5". The part number I listed is for the first kit, the 2" front only. KT09115BK is the part number for the 2.5/1.5 kit (as mentioned above).
