Daystar KT09115BK with 2010 FJ Bilstein setup
ronsta
Does anyone know if the daystar kit in the subject title is compatible with the 2010 Bilstein setup or would it require the daystar fj kit, part # KT09124BK ?
Thanks all
not sure if this helps, but I have 08 FJ coils and springs right now and the daystar 2.5/1.5 kit would not fit unless i was to use spring compressor or remove lower control arm. just an fyi
Hey mrpanic7, I'm adding the FJ coils to my DS 2.5 this Friday and would like to hear some feedback from you on the ride. do you have any pics?
best 100$ i ever spent :) Ill upload a pic in a bit, right now im only running FJ springs and shocks, no daystar. But there is big difference in ride. Less brake dive and body roll, and overall much better handling
you have the v6 or v8? tokiko fj shocks or bilsteins? How much lift overall do you think they added, front & rear?
Does anyone know if this would work on a sport? Basically the same set-up you all are proposing here, but on a sport edition with XREAS.
- Daystar KTO9115BK
- Stock FJ springs and Struts
- XREAS (obviously already installed as part of the stock sport set-up)
- Daystar KTO9115BK
your question isn't clear but if you plan on replacing the OEM struts/shocks with the FJs you will lose the XREAS.
Your Windex spraying and swiping are impeccable! I basically wanted to know if you could keep XREAS in tack with the FJ swap.
And since we're on the subject, why doesn't it work? Please excuse my mechanical clumsiness.
And an FYI ... your belayer just tied the line to a twig while he/she fetches a beer ...
The XREAS consists of crosslinked shocks that are only on the XREAS equipped 4runners. If you replace them with the FJ shocks, they don't have the XREAS connections. If you want to keep the XREAS, then you can install just the FJ springs and keep the stock 4runner XREAS shocks, however depending on the age and condition of the XREAS system you may be better off swapping to the FJ shocks if they have lower miles.
If I'm hangdogging on the route, my belayer can grab a beer :p
I have a Sport with the Daystar 2.5 lift and went in last week to 4wheelparts to see if they could install the FJ springs that I grabbed from the FJ forums. They were not interested in attempting since they'd have to disassemble the front struts. I'm waffling like Favre to either install them myself or sell the springs. I don't think any member on here has XREAS, DS & FJ springs...there maybe a good reason why not.
There have been on here who've ran that setup. There shouldn't be any issues. A lot of shops won't touch xreas because they don't want to be held liable if something happens since the system is very costly to replace. Do it yourself or find another installer, well worth it considering you already have the fj coils.
sorry im rocking a V6 with the black Tokicos and it gave me about 1/2" all round. The performance especially off road was the real value of it all
yeah, that's exactly what the guy told me that they didn't want to be liable...even though they installed my DS a few months back. As long as others have ran this setup with XREAS with success then I'll keep the springs and see if I can get some help with the install. Thanks for the nudge in the right direction ARK.
Seatown: Don't give up! I'm planning on doing mine within 2 weeks & I have XREAS, worst case scenario everything leaks & I'm stuck using FJ Bilstein coils/shocks !
Alright ronsta, you lead the way and I'll follow. Are you tackling the install yourself? Keep me posted on how everything works out for you and GOOD LUCK!!
I also currently have a Sport with the DS 2.5/1.5 XREAS setup and have FJ springs waiting to be installed. I plan on doing it myself once I can find someone to help me. I anticipate that it will be an extremely tight fit on the front and will need extra hands to assist. It was a tight fit with the spacer. If I get around to it first, I will let everyone know how it went.
Alright Burl! We're growing by the minute with this setup...can't wait to see it.
