DDM tuning hid help
Whiskey_Runner
So installed the kit yesterday . Low beams work just fine , but only the passengers high beam comes on . And now my fog lights won't work. Was wondering if anyone has ran into this issue before .
Also the high beam are adjusted by the fog light switch, which I thought was kinda weird
I put a hi/low 6K 55W kit on my 97 last winter, the lows worked fine, but the high beam only worked on the passenger side. I really didnt care because there is no difference in light output, the hi beams just move the bulbs forward and change the beam pattern. I was too lazy to take them back even though they are less than a mile from me, so I just left it. Stangely enough about a month ago I flipped the hi's on and both lights went to hi beam.
I dont have any fogs so I can't help you there.
Yeah I'm not as worried about the hi beams as I am my fogs . *****es are bright enough haha.
If I have to ill just re wire my fogs I guess
im taking that it only plugs into one side, thus the problem. it thinks a bulb is burt out. you either have to put a regular working bulb in the otherside and figure it to where it doesnt touch anything, like melting through you washer fluid fill... ugh... or get a very high wattage resistor to stick on the side that doesnt have the modual plugged into.
So I hooked up a extra 9003 bulb I had to the open socket . Sure enough the fogs kicked on ... so ill just have to figure this out . I see re wireing my fogs in the future.
