DDM Tuning Saber LED for DRL / High
I like the color and the drl is nice. It's not too bright or too dim. No my headlight isn't out. Not sure why it's doesn't look on in picture. I love the build quality though. I just need to test how bright the high beam is. The only thing was you have to kind of muscle it for the bulb to fully turn to right position
Sent from my SM-N910T using Tapatalk
what bulb did you use for the sidemarker?
Exactly 10 days later I have my DDM Saber's, I installed and very little wiggle if any and they are already set at 9 and 3 O'clock. I guess they emailed the factory in china and gave them a heads up so no adjusting needed.
It's not pitch black out yet and my wife parked her XT in front of me.....guess i have to pull out into the street later to try them out.
Super easy install, but i'll keep an eye on those itty bitty cooling fans from time to time and make sure they keep up, but with how little I use high beams im sure they will survive a while.
Do your drls have a super rapid, an almost unnoticeable pulse to them? I installed the same lights, the Morimoto 2 Strokes, and my high beams are perfect but the drls have a high frequency pulse to them. I asked the guy I bought them from and he checked the site again and apparently we need an extra harness that's coming out in about a week that corrects this issue. Something to do with the PWM. Other than that, they're bright as heck. And plus one on needing to muscle it in there!
Yes I did notice the pulse. I didn't know there's a fix for that. I'll ask tomorrow as well. Thanks for the info. But yea they are super bright!
Just installed my sabers... There was a bit of wiggle, but not sure it's enough to warrant swapping to the larger orings. That said, it's still light out here but man is there a difference between the oem high beams lighting up the wall in front of the car where it is parked and the LEDs. OEM was barely noticeable and the sabers show up bigtime. Even the DRL function shows up a bit on the wall. Can't wait to test them out tonight
I've been debating LED high beams but haven't made the jump yet as i still feel HIDs are the way to go still...i did the HID low beams from TRS and i love them, sharp cutoff still and quite bright...
what lightbar and mount did you use for the grill setup...im guessing you mounted it flush and cut out the grill to fit
more info please also
Opinion:
HID's are not the way to go for High Beams as the do not fire quick enough.
They are only used in High Beam applications when there is only one fixture and a gate drops open to allow all of the beam to project thru the projector lens. That was the way my older Tacoma HID's operated because the retrofit was replacing a double filament headlamp system.
When you ask a question about someone's light bar, you need to include whom you are asking....
my bad
SAKER the light bar in your grill is what I'm talking about from the OP
[MENTION=118423]555R[/MENTION] ,
Check my Sig, there is a link to my write-up for my LED LIGHT BAR INSTALL, if it is mine you are referring to.
Hope this helps. :D
I just purchase a slightly used 2016 4Runner limited and installed Diode Dynamics HIDs in place of the factory headlights and these:
https://www.amazon.com/gp/product/B00XOIO6IM/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
in place of the factory DRLs and they work great. No issues and only $25.
Derryck,
A totally different animal from what's being shown and discussed in this thread.... I have something similar to what you got on Amazon in my fogs. Not even close to the same type of product.
Good.... But not a HID / LED Good.
-A
Derryck,
-A
I understand completely but hard to beat for $25. I almost ordered the DRLs from Diode Dynamics with my HID headlight replacements but the ones I wanted there were $120 and after spending $40K on a truck and another $2K on mods (wheels, lighting, etc. ) I was getting the stink eye. And I'm trying to get my post count up enough to say hello...
