Dead rear/mirror defroster and rear wiper?
SkidPalace
Member
Hi all, I am hoping someone can help with a strange issue I am having with my 2015 Limited.
I got into my truck yesterday to find that the rear and mirror defrosters would not com on. The dash button does not even light. Oddly, the rear wiper does not work either.
Of course I did check the fuses but I see no obvious blown fuse.
I did use a pressure washer to clean my engine compartment the night before. Perhaps something got shorted?
I have a 200 mile ride home tomorrow from VT so it would be great if someone has an idea on what to check.
Thanks.
Yep. Had same problem. Make sure rear window all the way up. Rear window button right by the seat heater button, I must have tapped the window button without realizing it.
OMG you guys rock!
You’re absolutely right. My back window was down the slightest amount. Cracked it up tight and everything worked.
Thanks for your help!
Rear wiper doesn't work. defroster doesn't work...checked window, fuses and tried quick remedies but nothing seems to work...rear window only goes up and down with key in back door????
Is it possible that the window lock button is engaged in the cabin? Happened to me with the rear window down a tiny bit.
utkrstam
