Determine towing capacity?
Master Yoder
Hello, I have a 2002 Sport Edition 4Runner with the V6 engine, 4x4, from what I can tell the towing capacity is about 5,000 pounds from what I can tell but what are the main things I need to look for as far as length, weight and hitch of whatever I am towing?
Also if the item i am towing has breaks how much does that change things? I am thinking about towing one of the mobile lift buckets rigs you can rent at Home Depot but I don't have the details yet.
Ok, where to begin....:confused:
Your first going to want to look at the combined weight of the trailer and the item you are towing. That can't exceed the 5000lbs you stated. And most items over 3500lbs are required to have trailer brakes.
Second your going to want to look at the tongue weight, which I believe is 500lbs on the class of hitch that is installed on your 4Runner. This can be adjusted by moving your load forward or backward on the trailer. You'll want to try and center it as much as possible over the axles of the trailer.
Third your going to want to look at the width of the trailer and what roads you'll be towing on. Most highway lanes are at least 8 ft wide, but some back roads can be much less and you could run into problems if you are given an overly wide trailer. I'm guessing for what I think you will be towing that you will be given a regular utility trailer that is probably 6 ft wide and could possibly have brakes.
And as far as the brakes go, if you need to use them, you will need to have your 4Runner rewired to be able to install a brake controller box that will control the trailer's electric trailer brakes. A trailer, with brakes, will most likely have a 7 pin round plug, and I'm guessing your 4Runner has the 4 pin flat connector that is just for lights. Now if you get a trailer that has no brakes your 4 pin flat connector should be fine to just control the lights on the trailer.
Your going to want to keep track of this stuff because most times the workers at Home Depot, Lowes, etc. are not going to know the towing requirements of your vehicle. And they are not going to know how to safely set up the trailer to tow with your 4Runner.
IMHO I would not tow anything over 3000lbs, with that model 4Runner, unless the trailer had brakes and I had them wired up correctly. And if I am picturing what you are towing correctly, I think you should be fine.
EDIT Update: The boom I am looking at is 3400 lbs and the tongue weight is 242 lbs. I should be able to tow this with my 4Runner then right? Thanks for anyones help.
Here is a link to the specs.
help.http://www.jlg.com/products/product.asp?ProdID=255
Thanks for the info. Is it very complicated or expensive to wire a 4Runner for trailer breaks and if you do so can you still use a trailer without breaks?
I called the HD guy and he said the man lift should be well under 3,000 lbs so it looks like it might work. Do I need to worry about the length of the item I am towing?
I also need to buy a trailer hitch for my 4Runner, is there any thing specific I should look for or just buy a standard $20 or $30 one from Wal-Mart?
I appreciate anyones
your t4r is very similar to my 97 Tacoma setup. She'll likely tow the 3400lbs but probably not gonna like it too much. My 3.4L with 330+k on the clock handles my 3200 camper fine on the flat highways and around town, but does NOT like towing her uphill. My Brother's 4L taco is much happier. (One of the big reasons I went for the 4th gen with the v8, which barely knows the trailer is back there.)
It is neither very complicated Nor overly expensive to wire in the trailer break controller. I did it a few years ago on the 97 and then on my dad's Van. Here is what I used:
If you already have the 4 pole trailer wiring so I'll just post the additional parts you will want.
I highly recommend the folks from etrailer.com they have videos on youtube that cover this install and were quick to respond to support emails when I had a question during my Sunday installation.
Regards
Boort
Towing camper
I have a 2008 V6 4L 4Runner and am about to buy a rv trailer, haven't fully decided yet. The tow capacity of my 4Runner is 5,000#. Can I easily tow a 4000# trailer without too much difficulty or will this be a chore for my vehicle? Should I look more towards a 3000# rv trailer? And my understanding is the tongue weight limit is 500#. Should I look towards a less tongue weight in the 350# range?
Check my reply to your post on the other thread.
MaximussK
