Didn't make a mark on tripod, inboard and out board shaft
4RUNNER_2004
I am replacing my front driver side inner CV boot, but forgot make marks on tripod, inboard and outboard joint shafts. could i just put back in? would cause any damage? Thanks
I tried to put tripod into outboard joint shaft, i can put it in in any orientation, so why do we need marks on that.
do i need marks
9b465ae0-cdb4-4441-8c7b-083fab004a51_zps3e5e5829.jpg~original
In my experience it has more to do with the fact that all those components wear differently and/or some are balanced as assemblies. Meaning that by not marking it you may have installed a tripod onto a surface that was wearing differently than the orientation it was in originally; this could result in excessive slop, noise, premature wear, nothing at all, ect.
Its more for quality and/or keeping things together in the grooves/wear that it was in before than anything too significant as it doesn't need to be "timed."
Thank you very much for the answering.
I probably get wrong orientation when i put it in, but how do i know if i put inside (where direct to differential ) to out side(where direct to tire). i do find that grooves are different on each side, one side is to the end, one side is not.
anybody know which side is which? this tripod drive me crazy. Thanks.
charlesz
