Diffs and Transfer case fluid kit
Mowgli
Looking at changing my fluid in my diffs and transfer case. I did it 30k ago all with mobile 1 75w-90 since that’s what most recommended. I like to go back and try a 75w in the transfer case and noticed Ravenol now sells a whole kit with 75w and 75w-85 for $100. Has anyone used this in your diffs and TC and how did you like it? Compared to Mobil 1 since I know a lot of people were using that for awhile
Toyota 4Runner Transfer Case Fluid Types
That's a very nicely priced alternative to the OEM 75w fluid for the transfer case! Nice find!
I have not used it yet... but I have looked into this before and planning to use Ravenol (J1C1003 SAE 75W) for transfer case.
As a side note: I have used Ravenol antifreeze (FL22 Coolant) in my wife's car- no issues.
I only use 75-90. That's all Toyota uses as well according to my buddy who is a mechanic at Toyota. I think he said they recently discontinued the 75-85.
Redline has fluids that meet Toyota specs. Front and rear diff along with transfer case. I’ve had the fluid in my transfer and rear for awhile and have had no issues.
I think I’m just gonna use cheap synthetic in the front since I never activate it.
Errrmahgad! You did not mention the holiest of holy, Amswayoil!
(Weird how only people selling it have glowing reviews which entices people to buy the MLM oil)
But you were saying what I was thinking.
Redline stuff is overkill for most people here.
but dude.. the price was the reason why i went w/ redline. If i had to pay the same price for ravenol vs redline then i may as well get the redline stuff:
17.95 x 2 for transfer Redline MT-LV
17.50 x 5 (3 qts for rear, 2 quarts for front) of Redline 75w85
All I use is Redline stuff.
Their Heavy Shockproof gear oil is flipping amazing!
I bought into the Amsoil hype years ago, then saw some stuff at tracks that changed my mind :scared: and ran Redline since.
I buy in bulk for nine Toyotas and one Land Rover so it is fairly comparable to top shelf auto store stuff. Highest mileage in the fleet right now is over 515,000 miles, 36k+/yr. :banana:
Scotty mentions RL @ 4 minutes.
I like watching him for some reason.
I notice he has cases of RL in his garage.
Amsoil, POR 15 and Fluid Film are all "forum" products. Bought into the hype with each when I was younger, then I found out the "hard" way for each.
I also have Ravenol in my TC Since 30k and now at 40k, no problems. I may switch all to Redline 75w-85 at 60k since it meets the 75W spec.
i think youre switching fluids too soon.. the oem t/c fluid and gear oil would have easily made it past 100k.. these fluids dont contaminate like oil does...
i would recommend a complete ATF swap if youre still on OEM fluid
Peeps get bored, have money, and look for new/exotic stuff.
You notice this most with Amway/Amswayoil people.
They will change basically "brand new" fluids just to say they run forum darling brand, Amsoil.
What is Amway? (with pictures)
Pyramid Scheme Alert
I run Amsoil. However, I don't dump good fluids just run it (my 19 Runner still has factory fill minus the engine oil) and I don't advertise to the public (stickers) that I run it. It's not terribly expensive because I just run the OE line since I'm not looking to extend change intervals. Also I get a slight discount. Run what you want. Kendall makes good stuff. :fencing:
I’ve heard of quite a few dealers doing that also. From what I’ve heard they put that in your diffs and TC
The Ravenol 75w did not actually meet the Toyota spec when I last checked.
Neither does the 75-90 that most dealer put in
Does anyone have a link for the correct redline that meets specs for the diffs and tc?
I never said what mileage I’m at just that I last did it 30k ago.
I definitely would not run the same diff and TC fluid for 100k seeing as a tow a lot. Just the the ATF though
Fair enough, but I would feel safer with an oil that was spec'd, if previously, than an oil that was not; particularly where operating at the lower end of the viscosity range. The earlier FJ Cruiser manual called for 75w-90.
I rechecked, and the Ravenol site says the xfer case fluid meets Toyota’s-81081 fluid specs, but Toyota calls for the LF fluid, -81080. Confusing, and of unknown importance, but there it is. I went with the OEM fluid when in warranty.
Red Line Synthetic Oil
This for a 2015 4Runner
Red Line Synthetic Oil. MT-LV 70W/75W GL-4 Gear Oil
RED LINE MT-LV HIGH-PERFORMANCE GEAR OIL is a full-synthetic ester-based lubricant designed for use in manual transmissions and front-wheel-drive transaxles. This shear-stable formula resists breakdown for extended periods and offers more consistent viscosity in warm and cold temperatures for less gear noise and improved shifting. This fluid is less slippery for improved synchronizer coefficient of friction and offers stronger film strength for better wear protection.
Suitable replacement for:
API GL-4 / GL-3 / GL-1
SAE 70W/75W
BMW DTF 1
BMW X-Drive Transfer Case Fluid
BMW 83 22 0 306 816
BMW 83 22 0 397 244
BMW 83 22 2 409 710
Cadillac 19331044
Castrol BOT 270A - Graziano Transaxle for Aston Martin, Audi and Lamborghini
Castrol BOT 350 M3
Castrol BOT 303 mod
Chevron GS CALTEX MTF HD 70W
Chrysler/Dodge/Jeep 9.55550-MZ6
Dodge/Fiat 68092630AA
Ford XT-11-QDC
Ford WSS-M2C200-D2
GM 10-4037
GM 19259104
GM 19259105
Honda i-Shift MTF-3
Honda i-Shift MTF-III
Hyundai/Kia 00232-19063
Jaguar/Land Rover C2Z25586
MB A001 989 98 03 09
MB 235.10
MB 235.73
MB 317
MB 001 989 26 03 10
MB A 001 989 98 03 09
Nissan/Infinity 999MP-TF0870P
Nissan/Infinity TF0870
Porsche 000 043 300 36
Porsche 000 043 301 36
Porsche 000 043 305 63
Shell SPIRAX S6 GHME 70W
Shell TF 0870
SK HK MTF 70W
Toyota MT Gear Oil LV 75W
Toyota 08885-81040
Toyota/Lexus transfer case fluid "Genuine Gear Oil LF 75W“ 08885-81080
Toyota/Scion Manual Transmission Oil LV
Toyota/Scion 08885-81001
VW G 052 726
VW/Audi G 052 171
VW/Audi G 052 512 A2
VW/Audi G 055 515
VW/Audi G 052 527 A2
VW/Audi G 052 725
VW/Audi G 060 726 A2
VW/Audi G 070 726 A2
Red Line Synthetic Oil. 75W85 GL-5 Gear Oil
API GL-5
MT-1
MIL-L2105E
SAE J2360
Acura
Alfa Romeo
Audi
Buick
BMW/Mini 83 12 0 445 838
BMW/Mini 83 22 2 295 532
BMW/Mini 83 22 2 413 511
BMW/Mini 83 22 2 413 512
BMW/Mini 83 22 2 447 362
BMW/Mini Castrol, BOT 448
BMW/Mini Hypoid Axle Oil G1
BMW/Mini Hypoid Axle Oil G2
BMW/Mini Hypoid Axle Oil G3
BMW/Mini Hypoid Axle Oil G4
Cadillac
Chrysler/Dodge/Jeep 05136035AA
Chrysler/Dodge/Jeep 68083381AA
Fiat
Ford WSS-M2C942-A
Ford XY-75W85-QL
Genesis
GM 9986551
GM 19300457
GM 19418501
GM 88862826
GM 92184900
GM SAF Carbon Mod
GM SAF-EH MOD LV
GMC
Honda/Acura 08200-9014A
Honda/Acura Hypoid Gear Oil HGO-1
Hyundai
Infiniti
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda K020-01-SG1
MB 235.15
MB 235.62
MB 235.7
MB 235.74
MB 239.71
MB 239.72
MB A 000 989 73 04
MB A 000 989 88 03
MB A 001 989 59 03
MB A 0012 989 33 03
MB A 002 989 02 03
MG
Nissan/Infinity KDL38-75801P
Toyota/Lexus 08885-02506
Toyota/Lexus 08885-02606
Toyota/Lexus 08885-81060
Toyota/Lexus Gear Oil LT/LX
Volvo G 052 513
VW/Audi G 052 513
tuṣṭāva
