Disabling things on an 03
BRUIN8124
Newb questions, I know... I do not have an owners manual...
In an 03 4runner SR5 Sport 4X4...
How do you disable the beeps when locking/unlocking with keyless entry?
How do you disable the Seatbelt Nag alarm?
How do you disable the automatic door lock/unlock? (on speed or shifting out of park)
Thanks in advance!
You can unplug the unlock lock beep its located in the driver side front fender apron. Theres a black wire leading to it in the engine bay and a 10mm bolt holding it.
The auto lock feature can be changed easily. The instructions are on this site. I found them a long time ago using search.
Im not sure about the seat belt chime, my truck doesnt have it.
dealer. also read the manual its in there
Your dealer will be able to help you. I had my beeps turned off as well.
You can change the lock/unlock beep and the auto lock/unlock behavior using a scan tool like a Mini VCI cable. http://www.toyota-4runner.org/gener...-tis-techstream-8-x-windows-7-8-64-bit-3.html My dealer wanted $60 to do it, so I did it myself. I didn't see an option for the seatbelt chime, but I didn't look at every option yet.
I also set the timer that automatically locks the doors if you don't open one within 30 seconds of unlocking to 60 seconds instead. I think you can disable it, but it's nice if you sit on your keys inside and unlock without knowing it. Even 60 seconds is too short, but that's the longest I could set it without disabling it.
Thank you all for the responses!!! I really appreciate it. Door locks are all set. I can just deal with the seat belt nag and keykeaa entry beebeep.
Great forum!
D'Angelo
