**Ditch Light Bracket + LED pods - Group Buy**
I will switch to side shooter pods :)
Go ahead and switch me to the side shooters ��
Sent from my SM-G935T using Tapatalk
I'll also switch to the side shooter pods.
Please update list to indicate Side shooters for me too.
I'm willing to switch to the Side Shooter pods as well. :yo:
i will switch to Sideshooter Pods
I will switch to the side shooter pods as well
Please switch me to sideshooter pods. Thank you.
I'll switch my two 5D pods to sideshooters as well
I want to switch to the sideshooter pods as well!
well then.. LOL
[MENTION=122940]ramonortiz55[/MENTION] Can you update the main list to include the Toyota Factory Sqaure switch for me as well. TIA
Vendor is only worried about the Pod type and counts.
not really on the accessories -
You can do as you wish when you order. I wont be keeping the list updated in terms of add ons and accessories.
Anyone know how many amps each of these pods draws? I'm working off some numbers based on their power rating (watts) and a range of 6-12 volts. Need a more definite voltage to get a more definite current draw. Can these be powered using an add a circuit or is it recommended to connect straight to battery?
In! 4th gen 4runner:
Ditch light brackets + 5D Pods + Harness + 4Runner Relay Holder
I'm confused where did you see 4th gen ditch light brackets? All I saw was the hidden front bumper...if there are 4th gens as others have said i would definitely be in.
You're right, I totally skipped over this. I guess I'm out then. Sorry!
What's the difference between the Toyota Factory Rectangle Switch and Toyota Factory Square Switch, other than the shape/size obviously?
Different locations?
Per Rago Fabrication's website, the rectangle switch fits Toyota 4Runner 2003-2009 and the square switch fits Toyota 4Runner 2010-ON.
Can we add extra sets of the side shooter pods? How much per extra set?
Are the low profile brackets compatible with the side shooters? The included brackets look super tall.
Yep, I want to add the Factory Square switch as well.
And I would like to Switch to the Side Shooters as well.
AndiGarage
