Ditching xreas near doylestown pa
4rs
I'm near doylestown pa. I want to ditch the xreas. Thinking bilstein 5100 or open to other ideas. I don't have the capabilities of doing it. Any members want to make some money that's near?
I'm not too far from you, but I have no time. Have you tried to price the work out to an indy shop?
I used old man emu springs other things have u will need is drivers side spacer and depending on the lift you want get the differential drop
I went through wheelers offroad they were awesome
Here is the list of things I purchase
Front and rear struts
Front and rear ome springs
Kyb strut caps for the front I assembled them so I didn't have to take apart the old springs
Differential drop
I also replaced sway bar links just because my bushing were all bad (this isn't nessesary)
If you had air bags you will need the metaltech rear spring mounts for the bottom and the top bump stops that go ontop of the rear springs as well
Sent from my SM-G930W8 using Tapatalk
Here is what mine looks like after all that
That looks exactly how I want mine to look. Love it!
What size tires are those? And I was thinking of plasti dipping my stock wheels too until I get some pro comps. But are yours glossy or matte black? Did you also dip the roof rack?
Sent from my ZTE A2017U using Tapatalk
I will check the tire size for you I painted the rims with a semigloss plastidipped the emblems roof racks and anything that was silver.
Personally I would keep the emblems plastidipped and then take the time and paint larger things the plastidip is great for figuring out what you want to do for paint
erinobr2000
