DIY: Exterior Door Handle Removal
lightfreak
Exterior Door Handle Removal Tutorial - 4th Generation 4Runner ('03-'09)
Those of us in the salt belt have this nagging rust problem under the exterior door handles. It's been discussed here:
http://www.toyota-4runner.org/4th-gen-t4rs/64327-rust-beneath-door-handle-s.html
Mine started showing rust several years ago and has gotten worse over time.
Whether you have rust or not, if you're just replacing the handle for some other reason , I highly recommend getting these 3 parts from Toyota, the original nut and bolt are very likely seized and you won't be able to re-use them.
You'll need one of each per door. Same for all 4 doors.
90179-05118 nut
90386-08066 plastic bushing
69296-48010 bolt
The nut is updated from Toyota and is now treated and should not rust in the future.
IMG_0080_zpspj2evqty.jpg~original
This first post covers the rear door handle removal, same procedure for both rear doors. Pics will show the driver's side rear door.
Will update thread later with front door tutorials. Driver Front and Passenger Front are slightly different due to the key lock.
Reference diagram of the rear door lock and handle
First you'll need to remove the inner door panel to gain access to everything. Here's a video showing how.
https://www.youtube.com/watch?v=bFhs9b_SBz8
TOOLS
No.2 Phillips
T-27 Torx Head
5/32 Allen Head
4mm Punch
Hammer
Panel Removal tool (if metal, wrap it with tape so you don't scratch your paint)
Tools need to be 4+ inches long to reach into the door.
I also used a stubby No.2 Phillips screwdriver for the screw holding the inner door handle/lock to the door panel, I find it easier.
Socket wrench and penetrating lubricant will also come in handy
IMG_0050_zps71siiwzi.jpg~original
IMG_0056_zpsbboglkod.jpg~original
Once you have the door panel removed, peel back the vapor barrier carefully, about half way. You can re-seal it later when you're done.
IMG_0059copy_zpsk1gsxo7m.jpg~original
Note the 2 areas marked with a red arrow.
Peel off the white sticker covering the hole. There is a screw behind there you need access to.
Unhook the white connector.
Make note of the black ring around the connector, this ring is part of the lock mechinism inside the door.
Also make note of the blue film in the center of the vapor barrier , it has a slit in it which will come in handy shortly.
Next find the 3 torx screws on the side of the door, these hold in the lock mechnism.
IMG_0060_zpskp4scp77.jpg~original
Remove screws , socket wrench with torx head will come in handy here, they are on pretty tight.
The lock mechanism has 2 cables coming from it, and has the inner door handle/lock button on the other end of it.
To properly remove the lock mechanism, while supporting the lock on the screws side with your fingers, push the black ring through the hole until it clears,
then lower the lock mechanism 2 inches or so, then fish it out towards the opening of the vapor barrier.
Do this carefully, there is a plastic lever on the inside that interacts with the lock mech. Dropping it 2 inches will clear this lever. More on this plastic lever later.
Should look like this
IMG_0061_zpseigqcbfy.jpg~original
Run the cables and inner door handle through the slit in the middle of the vapor barrier. Put aside.
With that out of the way now you can start taking apart the plastic door handle frame support which sits inside the door.
Look through the hole where you removed the white sticker earlier, there is an allen screw there.
IMG_0065_zpshnlz3ktm.jpg~original
Unscrew it 5 or 6 rotations until fully loose. NOTE this screw does NOT come out, there is a retainer in the frame support holding it in place. You just need to loosen it in order to remove the cap on the other side.
Here is the cap on the other side:
IMG_0079_zpsc0rwjd3x.jpg~original
While holding the door handle slightly open, use your panel remover tool and pry out the flat side of the cap. It should pop right out.
IMG_0068copy_zpsgyzhcryh.jpg~original
Next you're going to remove the exterior door handle.
IMG_0068_zpsaml9tdux.jpg~original
Get a good grip of the handle, give it a good tug in the direction of the arrow. Once released you can wiggle it out.
IMG_0070_zpstvlroxat.jpg~original
Next remove the black rubber pad that sits under the handle. (you can remove the other pad too, or just leave it on the door)
Should now look like this, revealing the rusted nut.
IMG_0072_zpsa5qb8jih.jpg~original
The nut clamps against the door skin. Make a mental note of this for later.
Next look through the vapor barrier opening, towards the top, you should see this.
IMG_0066_zpsrpwmlkdz.jpg~original
That is the torx head bolt that is likely seized.
Give it a good twist and it should snap off clean.
Then take your punch and hammer and wack the bolt/nut from the inside out.
Get a friend to hold the door while you wack (LOL), or support the door with something sturdy.
I soaked it in Seafoam Deep Creep penetrating spray for a few minutes. Took a few hard wacks to pop out.
IMG_0074_zpshlpxgtsa.jpg~original
Once the nut is out, the door handle frame support should now be free.
Back to the exterior side, use some rubbing compound or scratch remover cream to clean the rust.
IMG_0075_zpsembclyhi.jpg~original
The new bushing slips over the new nut like so
IMG_0054_zpsl438eqfp.jpg~original
Now it's just a matter of reversing all the steps.
When you're re-installing the door lock mechanism, swing the lever on the frame support towards the exterior, then put the lock mech in place ensuring the lever catches the part on the loch mech.
Lock mech on the left, lever from frame support on the right.
IMG_0076_zpsnroquxtk.jpg~original
Another view
IMG_0077_zpsawx8zr9t.jpg~original
When done , I put a piece of tape over the hole where the sticker used to be, and greased the lock mech.
Should take about 30 minutes or less to complete one door.
Good luck!
Best write-up I've seen on this topic to date on this site. Great job!
Eager to see the pics of the front.
Luke
I was able to do the front passenger door today, and as promised here's the writeup.
Passenger Front Door Handle Removal
Here's the factory diagram for the front doors.
4runner-front-door-handle-lock-672805B_zps24bkogzd.jpg~original
GOOD NEWS! If you're just replacing the door handle this will be a very quick job. No need to remove the door panel and there's no messing around with the lock mechanism!
Same tools in the first post will be fine.
I did recently pickup a plastic panel removal tool set , did come in handy and made the job easier and no worries scratching anything. I ended up using this one from the set
IMG_0132_zpsanvvd0zw.jpg~original
First, open the door and look for this rubber plug
IMG_0129_zpsbieh9txf.jpg~original
Use the tool to remove the plug
IMG_0131_zpsvrdctviv.jpg~original
Once removed, look in the hole, there's a torx bolt in there you will need to LOOSEN. It sits at an angle, I had no problem getting to it with the tools listed above. NOTE THIS BOLT DOES NOT COME OUT, there are retainer tabs holding it in the frame support. Just loosen it all the way.
IMG_0133_zpsm2rek2cx.jpg~original
This torx bolt screws into the door handle cap on the outside of the door.
Here's the cap on the outside of the door.
IMG_0135_zpsba22imop.jpg~original
Use the tool to gently pry it out. Open the door handle a bit to get more space to work with.
Cap removed
IMG_0136_zpsfhn63ppo.jpg~original
Now just grab the handle and give it a good tug in the direction of the arrow, then wiggle it straight out.
IMG_0137_zpsg5lcgsi5.jpg~original
Removed
IMG_0138_zpsvhyiw5ak.jpg~original
If you're just replacing door handles, now just reverse the steps with the new door handle installed and you're done.
Below are additional steps to get to the door handle frame support.
The rusted bolt/washer on my passenger front wasn't as bad as the rears, but I replaced it anyway. I used same OEM replacement bolt/nut/bushing as posted above
First you'll need to get the door panel off. Good write-up here:
http://www.toyota-4runner.org/engin...-idiots-guide-door-panel-removal-4th-gen.html
**Make sure window is rolled UP ALL THE WAY**
Once the panel is removed , peel back the top part of the vapor barrier, so it looks like this
IMG_0142_zpstmzs1oh9.jpg~original
Next remove the front rubber door handle seal revealing the rusted nut underneath, and re-install the cap (I'll explain why shortly)
IMG_0144_zpsdllqiato.jpg~original
Spray some penetrating lube on the nut and let soak for a few minutes
Look inside the vapor barrier opening, this torx bolt securing the door handle frame support needs to be removed. As with the rear doors, it may be seized.
IMG_0141_zpsr4il6ipt.jpg~original
Give it a good turn , if it breaks off , use a punch and hammer to pound out the nut from the inside out (like with the rear door in the first post here)
If it doesn't break off, and the screw comes out , you will still need to use a punch to pound the nut from the inside out. I've found a 4.8mm punch actually fits better than the 4.0mm punch used in the first post. And a few wacks got the nut out clean
IMG_0146_zpsccv75imn.jpg~original
Nut and bolt still in one piece
IMG_0148_zps3r546uzv.jpg~original
The reason I re-installed the cap was to prevent the frame support from falling inside the door, Once the nut is pounded out there would otherwise be nothing holding the frame support in place. Unlike the rear doors, the passenger front door does't require the lock mech to be removed at all.
If the frame support falls inside the door the wrong way, you may need to remove the loch mech just to get the frame support back out. Hope that makes sense.
Next clean the rust off and insert the new nut/bushing into the frame support, clamping it against the door skin like the original. Then remove the cap, because the door handle won't go in with it installed.
IMG_0147_zpspiixesbf.jpg~original
Now just reverse all the steps, re-seal vapor barrier, put your panel back on and hopefully you don't need to do this ever again LOL.
Total time spent on passenger front , 25 minutes, including taking pictures.
I'll do a very short write-up of the driver's front soon, much of the steps are the same as the passenger.
Good luck!
Driver's Front Door Handle Removal
Exact same procedure as the Passenger front!
The only difference is the door handle cap on the driver's side has a key lock assembly, just need to be a little careful you don't bend or break the arm.
Pry it out gently, working all corners little by little.
Once you get it out about this far, pull it straight out
IMG_0250_zpsh24equzx.jpg~original
Removed
IMG_0251_zpsqwmemao0.jpg~original
While it's out, I cleaned and lubed it with di-electric lubricant.
The blurred part is the key code engraved on the side of the assembly. If you ever need this part replaced make sure you get the same coded part or your keys won't work. This code should match the little key code tag that originally came with the car when purchased new.
I also replaced the rusted nut and bolt on this door.
Snapped off clean with very little force. The bolt was barely hanging on.
IMG_0254_zpsmwalkras.jpg~original
New nut and most of the rust cleaned off. This was the worst out of the 4 doors
IMG_0255_zpsubuk6zmj.jpg~original
That completes this DIY tutorial. Any questions , just ask!
None of the pics are showing for me, anyone else?
It's Photobucket, they now charge to post photos on forum/blogs, etc., no longer free, hopefully they will see the error of their greed and go back to the way it was, but you may be able to open the photos in another "tab" and view them on Photobucket by right clicking on the "photo" and clicking "open image in new tab", just worked for me using Chrome as my browser.
What parts do I need?
I am wanting to replace my chrome door handles for color keyed handles on my 2008. I know the door handle is 2 pieces for each door, but it looks like there is another part I may need (some sort lf pad?) Can anyone help me?
Need Some Help Please
I know this is an old thread but I'm desperate, lol!!!! I have a 2007 Limited and I replaced the door actuator on the drivers door but I can't get the lock to fully seat back in place. It's not rocket science, I've replaced many Toyota actuators and never had an issue. The lock goes in but stops 3/16 to 1/4 from being fully seated. The t shaped rod is in the same orientation as the piece on the actuator goes into. I have tried pulling out slightly on the handle to see if that will allow it to drop in place and I made sure the retaining bolt is backed out as far as possible, but it still won't fully seat. The new actuator works when I push the lock and unlock switch on the door which it didn't do before, but for the life of me I can't get this lock to fully seat. I hope somebody can tell me what I need to do. Thanks in advance for your help. God Bless
NCH
Found The Problem
Going to post this in case anyone else runs into the same problem. I took the actuator out and the plastic "+" piece that the lock arm goes into is installed wrong. It will only go in if it's aligned correctly. The small pieces that form the + aren't the same, they are different thicknesses. Whoever assembled this has got them in wrong so it's impossible for the lock arm to be inserted. I sure hope that I can take this actuator apart and rotate that piece so it's in the correct alignment. I tried inserting a large screwdriver into it to see if I could rotate it, but of course I couldn't, that would be far to easy, right? Here goes nuttin.
NCH
Thx for this post. Helped me reattach the rear driver door handle cap that somehow loosened itself since 2009 and came completely off when we reached our campsite this past weekend.
A few differences on my 2009... The torx screws were all T30 (not T27). Also the screw holding the cap from the inside was also T30 (not 5/32 Allen).
I went ahead and applied some loctite to the screw while I was at it.
Sent from my Pixel 3a using Tapatalk
Thank You
I purchased 4 nuts, 4 bolts and 4 replacement bushings. Between drinking coffee and using the restroom, I started at 8 AM and was done at 11:30 AM, working in the rain.
The drivers side front had me baffled for a bit but I figured it out and got it done. I think the locking mechanism had me scared but in the end, it was no big deal.
No issues which is shocking! I guess 3 out of 4 bolts breaking would be an issue but good planning helped solve that before it was a problem.
I just recently purchased this 4th gen and those rust marks were bugging me so I’m glad that’s taken care of.
Thank again for the write up.
This looks like the passanger door. How does the driver's door cover with the key pop out?
Mad props to you lightfreak for an awesomely detailed posting.
A couple of my observations, I just completed removal of chrome handles and replacement with black (202 color) . 06 V8 SR5 4wd 4Runner
Sorry to get wordy but the devil is in the details right?
The parts numbers listed for replacement have changed slightly, either over the years or for my year of Runner. Your rust issue was significantly worse than mine, and I chose not to replace the hardware.
Once I removed each door's handle I taped off the striker plate to prevent accidental closure of the door being worked on.
I used a good deal of masking tape all around the handle so that I would not mar the paint while popping off the small cover.
The driver's door lock insert gave me the most single irritation. I could not make the lock cylinder insert far enough into the door to mate up the T30 screw. Neighbor suggestion of turning the key within the cylinder to locking position gave that extra 16th of an inch to make it line up. No such issue with the passenger front door, and of course no lock insert anyways...
For the rear doors, that plastic fork surrounding the locking post is troublesome to see what you are doing. A 'dental' type mirror and flashlight is your friend to see what is going on as you raise the latch mechanism back up into place. Ultimately my helper used a feel by Braille technique so to speak to line it up.
As with most automotive projects, a second set of hands/attentive listener is helpful to talk it out with along the way. Don't rush the work, it always takes 3 times longer than these guys say online.
You may want to replace the rubbery pads underneath, but probably won't actually need to.
For the rust itself, mine was only originating from the washer resting against the body. Again, taping off the good paint my helper used a die grinder with very small wheel to remove all rust from the washer. I then went after rust colored paint with a clay bar and great deal of patience. Once I removed all possible discoloration I treated the metal of the washer with Rust Dissolver by Loctite, about $9 a bottle. Then I primed
the metal with Etching Primer (spray some into a small glass jar for example) using a hobby paint brush.
Working in 95 degree heat all liquids dried extremely quickly, I over primed areas that were hidden by the handle pads anyways, no one will ever see them.
I am available to help users running across this while it is still fresh in my mind, July of 2026. Though I rarely check email, I will welcome all text messages 720-635-2621, and try to help talk it through with you.
