DIY "Gobi Style" Roof Rack Build
jakerunner
After months of wanting a Gobi Stealth Rack for my 5th gen, but without the cash for one, I finally pulled the trigger...and built one.
Gobi is kind enough to provide specs on the material their rack is made of on the product page (16 gauge, 1 inch steel tubing) and the length, width, and height. This gave me a good starting point.
I drew it up in Fusion 360 just for kicks, and 3D printed a little model to get a look at it.
I bought 8 20' lengths of tubing, a sheet of 3/4" expanded metal, and some 6x6x1/4" plates. Also picked up some pre-punched weld tabs for misc mounting points. Total about $180
As for tools, I decided to pick up a pipe notcher from harbor freight ($50). Rather than buy an expensive bending tool, I made my own wooden bending jigs ($10), and they ended up working just as planned. These were mounted on a sheet of plywood and moved around, and I hand bent each piece around them. It gave me a good result for the simplicity, with very little flattening and no kinking issues.IMG_6296 2.jpg
I had access to a wire welder (much needed when working with the relatively thin tubing)
After getting everything cut, bent, and notched, I tacked it together to make sure everything fit and that I liked how it looked. The hardest part was the feet that connect the rack to the mounting points on the car. It took a lot of trial and error to get the mounting holes to line up.
Once I was sure everything was going to fit, I finished welding and cleaned it up with some grinding.
Planning on a coat of primer, followed by some some spray-on black truck bed liner.
Until that's done, lots of pictures!
Cheers
That's awesome! The bender is the best part. I use 3D software, but im throughly convinced that 3D printers are a straight-up witchcraft! I love anything DIY, it's 1/2 the fun!
Matt
Did you make the ladder aswell? You might be to cool for school!
I'm sure you'll get a cease and stop copying from gobi, but more power to you!!
I've been contemplating this. I think I may have to now! Do you have any close ups of how you mounted it?
I can take some pictures of the mounting brackets tomorrow. I used the stock rack mounting points, and built some s-shaped brackets to connect that to the rack.
These brackets are probably the least-pretty part of my whole rack though. Long story short, I ended up having to mount the rack an inch higher than planned, so I had to add steel spacers to the bolts between the brackets and the rack. I will probably remake the brackets in the next 6 months just because, but figured I might as well wait and see what other problems arise after having the rack on there for awhile.
If you do decide to make one similar, shoot me a message, I can share some of the things I didn't think of the first time through and maybe save you a few hiccups.
-Jake
Yes I did make the ladder as well (I'm pretty proud it came out so well hehe). Functionality wise though, I may rework it, as it would be nice to have a little more room between it and the back door when climbing those rungs.
As for Gobi, so long as I'm not trying to sell anything resembling their products, I believe I can kindly tell them to leave me alone. I shall build whatever I want for myself.:cool:
-Jake
Thanks! I was planning on building one for my FJ80 but I sold it before I got around to it. Now with the T4R I'm back on the idea. I was planning on trying a conduit bender but if that doesn't work I'll use your "bender" idea. Nice work!
Nice! I drafted up a Gobi-inspired roof rack in SolidWorks with the possible intent to see if the guys at my company's shop would be willing to let me pay them for some after-hours labor to fab me one up. I need to pull off the OEM roof rack to get some measurements on the mounting holes though. (if you have those dimensions already, I'd love for you to send them my way!)
Yours looks great!
Here's some pics of my rather rough mounting brackets. They're not perfect, they're one of the parts I will probably redo within the next 6 months.
Also, here are some measurements for the location of the mounting holes on the roof.
Thanks man! I'm on a mission now. [emoji41]
Aaahhh shit, you're the man (or woman, whichever)!
Maybe I'll make up some drawings for open-source use for people to have their own racks fabricated. Muahaha!
Awesome, I still don't understand why these racks cost $1600-$1900 for some round tubing welded together and some thin paint slapped on that doesn't last 6 months without rusting. Crazy.
usedautopartspro
