Do I have XREAS?
A10MileHusker
WARNING!!!!! I'm about to sound as dumb as a newborn.
How do I know if I have XREAS?
I have some mod's coming up that if I have XREAS then I'm screwed. I don't think I do but when I went to install my sliders I saw some lines that look, to me, to be associated with XREAS.
Would I know if I had XREAS?
This is my first 4R so I'm going off of my experience with the Range Rover and their air suspension when you'd know if you had it.
Thanks for the help guys!
Doug
Well given that you probably have an SE (what your sig says), then you have X-REAS standard. But otherwise the way to tell is that there is a fluid line coming off of the top of the shocks.
Agreed, you have it since its a sport. You can always take it off if you replace all the shocks. And the lines only come out of the top of the rear shocks. In front, they come out of the bottom. On the sides of your frame rails should be a cylinder, one on the left and one on the right about halfway between the wheel well that says YAMAHA on the side, that is the key part of X-REAS.
Crap...That's not what I was wanting to hear.
Thanks guys.
Doug
Yep. Those lines are for the Xreas system. Just this weekend I was looking for a mounting point for sliders and ran into the same problem as you.
If you figure it out, share the knowledge with the rest of us. :D
jisoo200
