1engineer
Moderator
A great question. I have neither any documentation nor calculation to back it up. My 2014 Camry LE came with steel rims and had acorn lug nuts. I bought SE rims for my Camry and had to buy a set of mag type lug nuts. As far as I can tell (with my untrained eyes), the spare steel rim looks same as my steel rims. I am not sure what calculation I can perform (even if I were smart enough to do that). The mag type lug nuts are the best fit (IMHO) for Toyota OEM alloy rims but not necessary true (IMHO) for the steel rims. Coversely, acorn lug nuts will not be best (IMHO) for Toyota OEM alloy rims. I know there is no math behind this but please try a mag type lug nut and acorn type lug nut on a steel rim and tell me which lug nut type you prefer holding on the wheel. If you know how to perform calculation, I am willing to give it a try but you will have to go easy on me.
I wrote a short article here awhile back when some members had studs break from over torque. A mechanical fastener, in this case a nut and bolt, depends on clamp force and length of thread engagement. This assumes the material spec is adequate of course.
Clamp force is measured in lb-ft of torque and length of engagement is simply that. Bottom line is if the nut is of correct material, has the proper thread engagement, is able to seat firmly against the wheel with full shoulder contact and can be torqued to published values then it won't matter which nut you use, acorn or open.
I will try to find my early post to show a sample of how proper torque calculations are done. This also includes thread stretch.
Edit: Here's is one place http://www.toyota-4runner.org/5th-gen-t4rs/95630-broken-stretched-lug-stud-issue-solved.html I discussed the lug bolt torque and lubrication. I did another full write up but cannot find it at the moment. Oh, post #11 is my input.
