Dobinsons 5th Gen T4R Suspension options - from Exit Offroad
Can anyone comment on ride quality for the 220lb rear coils for a car with no extra weight? I'm not happy with my current springs regarding harshness on bumps (over sprung imo).
My fronts with king 550lb springs feels like a push pillow in comparison.
What springs are you currently running in the back?
The closest match would probably be the 186lb Bilstein rear springs.
The Wheelers T13 is 196 and the Eibach I have is 204 or so.
I cannot see how a 550 front can work with 220lb on an empty rear either.
I have the T13, supposedly 12% over stock rate. It's okayish but my front feels like the holy grail I'm chasing.
So you have the equivalent Kings in the back?
The front will always feel better simply because it is IFS.
Plus, if the front is that plush, it may actually be too soft offroad. You can tell by the way it comes off a curb or even by the presence or absence of brake dive. If comfort is supreme, but brake dive is more than minimal, it will be too soft offroad (hitting bump stops, hitting rocks).
Ya 2.5 kings. On forest roads I can bomb pretty fast, haven't hit the bump stops. I have 3in of droop in the front which is what king recommends. Maybe I should drop in the factory springs and see how they feel, maybe my expectations are unreasonable for the rear like you mention.
That can work but only if the Kings are ok with a 0" rear lift. If the shaft is totally out of position, the experiment won't work without spacers.
I am at about 4.5" up travel and 4" down travel in the front. In the rear I have 4" and 5.5" respectively. Uptravel is hard to measure precisely though.
Any of the easy/faster desert trails proper will tell you what the truth is :) You should be golden on forest roads and in low range with the T13 anyway.
How’s the corrosion resistance on the IMS systems? I live in Ohio and they love their salt in the winter here in Columbus.
Dobinson kit installed
Front
C59-354 coils
GS59-700 struts
Treaty oak spacer
Dobinson UCA's
Rear
C59-329 coils
GS59-701 shocks
Treaty oak spacers
Tires are 265/70R17's, planning on going up to 275's, I think.
Even without the requisite weight this setup is rated for, the ride is very comfortable. Skids and sliders already installed. Planning on a full bumper/winch up front and victory rear bumper with rago fab shelf, gear plate and various gear bags in the rear.
Can't say enough about Mike's customer service answering all my questions and the quick shipping.
Front
C59-354 coils
GS59-700 struts
Treaty oak spacer
Dobinson UCA's
Rear
C59-329 coils
GS59-701 shocks
Treaty oak spacers
Thanks man, it looks great!!
Hey guys, my name is Mike Tomczyk (aka Crikeymike), owner at ExitOffroad.com. I've been in the 4x4 industry since 1998 and have always preferred to focus on suspension for 4x4's, since it's something you'll feel every single time you move your vehicle, whether driving to work or home, or offroad for the weekend. Everyone has their own build plans for their vehicle, so no same combo of parts is necessarily right for everyone, which is why we offer such a variety - to get you exactly what you're looking for!!
I've been blasted with a lot of questions recently about our suspension offerings for the 5th Gen 4Runners, so I figured it's time to make a specific post about all that we offer. We can lift anywhere from 1.0" to 3.0" with coils and struts/shocks, and we can put together a specific package for whatever you want/need, including the added weight you've added to your vehicle.
Public Notice: Stock/New hub to fender measurements average out to 20" front and 22" rear, and all lift heights are based on that. Many people have 1/2" variance based on age and how the truck came off the assembly line. This video here shows you how to measure your baseline and lifted height:
<br>
<iframe width="560" height="315" src="https://www.youtube.com/embed/w7IgfWU1Awo" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<br>
Added Load Weight.
How much extra accessory weight have you added to your truck? Did you add a 150LB front bumper and an 80LB winch? That's constant weight, and will change which coil to buy.
Did you add our drawer system (hopefully) to the back end (150LBS) or a steel bumper with swing out tire carrier (200LBS)? That will also change which coil we would suggest.
You will want to consider that weight before ordering. If you order a heavy load coil without a heavy load, be warned that it won't ride as it's supposed to and the lift height will be incorrect.
Contact me directly if you have KDSS and I can walk you through our options for that. FYI, vehicles with KDSS should add our 15mm spacer (PS59-4025) onto the rear passenger side to correct the lean that usually happens on 1.5" or more of lift in the rear.
Full suspension builder page is here, with every part number and option offered for a 5th Gen 4runner:
Dobinsons 5th Gen Suspension Builder Page - Every Option
Dobinsons IMS 4Runner Lift Kit Builder Page
Dobinsons MRA 4Runner Lift Kit Builder Page
Click on each part number to be directed for further information
Front Coil Options, even height left to right. KDSS vehicles over 2" of lift should add PS59-4030 1/4" spacer to passenger side strut mount to correct the lean
C59-238 - Stock front end, low height lift, 1.0"-1.25" lift. 375/375mm, 17mm wire, 586LB (teal only)
C59-296 - Stock front end load, 1.4"-1.5" lift. 378/378mm, 17mm wire, 586LB (teal only)
C59-300 - Stock front end load, 1.75" lift. 385/385mm, 17mm wire, 586LB
C59-302 - 100-220LBS heavy load front weight, 2" lift. 395/395mm, 17mm wire, 586LB
C59-302 - Stock front end load, 2.5" lift. 395/395mm, 17mm wire, 586LB
C59-314 - 80-150LBS medium load front weight, 2" lift. 405/405mm, 17mm wire, 586LB or these same coils will give 2.5" with light front accessory weight of 50-80LBS, or 3" of lift with no front accessory weight.
C59-350 - 200-240LBS heavy load front weight, 2" lift. 380/380mm, 18mm wire, 730LB
C59-352 - 200-240LBS heavy load front weight, 2.25-2.5" lift. 385/385mm, 18mm wire, 730LB
C59-354 - V6 - 200-240LBS heavy load front weight, 3" lift. 390/390mm, 18mm wire, 730LB
***2.5" or more of lift, new UCA's are recommended***
TRD PRO Front Coils
C59-748R - 1.0" Lift coils for TRD Pro 4Runners with Bilstein or Fox Pro Struts, designed to add 1" lift over stock Pro height, same spring rate as stock (518LBS) but taller coils to add lift, 14.09" free height (teal or red). WILL ONLY REPLACE COILS THAT ARE FLAT TOP AND BOTTOM, NOT THE 2021 UPDATED VERSION WITH THE STEP IN THE LOWER COIL SEAT
Rear Coil Options, even left to right height **for KDSS vehicles, use a 15mm (PS59-4025) rear spacer on the passenger side to correct the lean on lift heights of 1.5" or more
C59-323 - Stock height rear coils, same specs as rear TRD Pro OE coils, 375/375mm, 17mm wire, 220LB (teal only)
C59-599 - Stock rear end, 1.0"-1.25" lift (keeps rear end low, allowing to help level the vehicle rake with 2" front lift). 390/390mm, 17mm wire, 220LB
C59-505 - Stock rear end load, 1.5" lift. 405/405mm, 17mm wire, 220LB
C59-325 - Stock rear end load, 2.0" to 2.25" lift. 420/420mm, 17mm wire, 220LB
C59-327 - 200-400LB heavy rear load weight, 2" lift. 410/410mm, 18mm wire, 271LB
C59-329 - 600-800LB super ridiculous heavy rear load weight, 2" lift. 410/410mm, 18mm wire, 286LB (teal only)
C59-331 - 800LB+ insanely heavy rear end weight, 2" lift. 410/410mm, 19mm wire, 349LB (teal)
C59-675V - Variable rate comfort option, stock rear weight, 3" lift. 470/470mm, 16mm wire, 157-230LB variable
C59-677V - Variable rate, 200-400LB constant rear load weight, 3" lift, long travel. 500/500mm, 16mm wire, 157-230LB variable
C59-701V - Variable rate, 500-600 LB heavy rear load weight, 3" lift, long travel. 500/500mm, 17mm wire, 210-245LB variable. Designed for those with heavy full rear bumper, tire carrier, roof rack, RTT, drawers, and fridge. Rides very well with all that weight, as well as when loaded even further.
C59-749V - Variable Rate, 800-1000 LB super heavy constant rear load, 3" lift, long travel. 520/520mm free height, 18mm wire, 198-300LB variable rate, usually around 270LB at loaded height
Note: Vehicles with KDSS should be lifted no more than 2.5" in the rear or you will probably have a lean that you cannot correct.
Front Strut Options
GS59-700 - Twin Tube, fixed mount (not adjustable), suits 0-2.5" lift (21.3" extended length), can be used on stock height or lifted vehicle, use with OE or aftermarket coils, coil seat mount same as OE
GS59-574 - Twin Tube, fixed mount (not adjustable), long travel (22.63" extended length), use with 2" coil to get 3" lift (coil seat height is 13mm higher than OE, resulting in ~1" of lift). Using this with a 3" length coil would give 4", so not recommended. Diff drop kit is required to run these, as CV's will bind at full down travel due to the extended length.
IMS59-50700 - IMS Front Struts - suits 0-3" lift - 560mm extended, 420mm compressed
IMS59-50574 - IMS Front Long Travel Struts - suits 2-3.5" lift - 575mm extended, 430mm compressed
MRA59-A700 - MRA 3-way adjustable monotubes - suitable for 0-3" front lift. 560mm extended, 420mm compressed
MRA59-A574 MRA 3-way adjustable monotubes Front Long Travel - suitable for 2-3.5" lift - 575mm extended, 430mm compressed
Rear Shock Options
GS59-701 - Twin Tube, suits 0-2.5" lift. 605mm extended, 362mm compressed
GS59-705 - Twin Tube, suits 0-2.5" lift, softer valving for empty rear ends. 590mm extended, 355mm compressed
GS59-575 - Twin Tube, Long Travel, suits 3-3.5" lift (3" bump stop spacers recommended so shocks don't bottom out). 730mm extended, 425mm compressed. - Cannot be used with KDSS
IMS59-50705 - IMS Rear Shocks comfort valved - suits 0-3" lift - due March 2020
IMS59-50701 - IMS Rear Shocks medium/heavy valved - suits 0-3" lift - due March 2020 (uses these for a vehicle with constant rear weight)
IMS59-50575 - IMS Rear Long Travel Shocks - suits 3"+ lift (not for KDSS models)
MRA59-A701 - MRA 3-way adjustable monotubes (comfort valved) - suitable for 0-3" rear lift. 609mm extended, 389mm compressed
MRA59-A575 - MRA 3-way adjustable monotubes - Long Travel - suits 2-3.5" lift - 730mm extended, 425mm compressed
Dobinsons 3-way adjustable MRA struts and shocks have their own thread, here: Dobinsons MRA - 3-way adjustable struts/shocks w/resi - 5th Gen VIDEO LINK
Diff Drop Kit
DD59-527K - required with 3" lift, could also be used for 2" to 2.5" lifts if desired to correct CV angle
Adjustable Panhard Rod
PR59-1423 - Rear adjustable panhard rod, realigns rear axle back to center when lifted 3"+ VIDEO LINK
Adjustable Rear Control Arms
WA59-520K - Rear Lower Adjustable Control Arms
WA59-522K - Rear Upper Adjustable Control Arms
Front sway bar relocation kit (only for non-KDSS vehicles)
Gains clearance around bigger/thicker front struts and coils, if needed, as well as helps correct sway bar operating angle with lifts over 2". (currently in re-design)
Rear sway bar extended length end links
SE59-529 - Suits lift up to 4". Uses factory style ball joint ends, gold zinc plated. Repositions rear sway bar to original position to remove stress from the rear end and correct the amount of wheel travel. VIDEO LINK
Front UCA's
UCA59-002K - Front UCA Set with Senkei 555 Ball joints - Pair of replacement upper control arms to fix alignment issues with 2.5"+ lift heights. Use OE type rubber bushes on the frame end, and replaceable high angle ball joint on the wheel side. 38mm OD tube, 5mm wall thickness (0.2") HSLA steel. Fixed caster of 3 degrees built in. VIDEO LINK
Front Strut Top Caps/Hats
SC59-001 - New upper caps - don't waste time pulling apart your old strut assembly just to get the cap off, buy new. Or better yet, we can assemble the units before shipping so you can install at home faster.
Front Top Mount Strut Spacer - new February 2019
PS59-4030 - Single 1/4" machine alloy strut spacer, anodized black, suits almost all Toyota's from the 90's to current. Drilled with 2 bolt patterns to fit multiple vehicles. 4Runner 3rd, 4th, and 5th Gen. All Tacoma's 1998 to 2019. All GX470/460. All FJ Cruisers. Can be used to correct a vehicle lean if one exists, or to add one to both sides to add 1/2" lift.
Rear Coil Spacers
PS59-4025 - Single 15mm Poly Coil Spacer to correct vehicle lean - recommended for vehicles with KDSS, install on the passenger side
CV Boot Kits
High clearance stretch style CV boots for the outer or inner position of the front shafts. High quality silicone, includes all new grease and clamps - great for lifted vehicles with higher angle CV's which are prone to boot failure. Boots have better designed bellows, less likely to rub and make contact with each other for longevity.
CV59-554K - Outer CV Boot Kit
CV59-557K - Inner CV Boot Kit (new September 2020)
We stock these parts in Miami, but if we were to run out, or have to make a special order, or custom make some coils, they would ship from Queensland, Australia.
What we get the most demand/requests from customers is our 3" front and 2" rear (leveling the vehicle), or 3" front and 3" rear progressive/variable rate coils with long travel struts and shocks. This will give the most travel and flex with just a few extra components needed. We also have options for 3/3", 2/2", 2/1", 2.5/1.5", or whatever lift height options you want to run. Lately, 2" front and 1" rear is very common (300 and 599 coils).
Added 8/29/17: Here is an album I just created trying to collectively gather all the photos I can of installed Dobinsons products. I'm showing the part numbers used and lift height gained, where possible.
Check out gallery here
Update 12/15/17.
Bring on the kicking and screaming from those who have already bought..... :wacko: :yield:
Due to popular demand and an amazing amount of requests, we have brought our most common 4Runner (and Toyota) coils to the US in 2 additional colors. Red and black. Now these part numbers are available (depending on stock) in classic Dobinsons Teal, TRD Red, and/or Black, depending on part number.
C59-300 (Teal, red or black)
C59-302 (Teal, red or black)
C59-314 (Teal, red or black)
C59-350 (Teal, red or black)
C59-352 (Teal, red or black)
C59-354 (Teal, red or black)
C59-599 (Teal, red or black)
C59-505 (Teal, red or black)
C59-325 (Teal, red or black)
C59-327 (Teal, red or black)
C59-675V (Teal, red or black)
C59-677V (Teal, red or black)
C59-701V (Teal, red or black)
C59-749V (Teal, red or black)
Of course, we would prefer to sell the teal for branding reasons, but so many of you this year have asked us for a color choice, so here you go!!
NOTE: the optional colors are not listed in the catalog, and are not sold on Amazon or Ebay. You have to contact me directly and let me know what you want. They're all the same price as usual. As usual, send me an email to [email protected]
<iframe width="560" height="315" src="https://www.youtube.com/embed/CmjVHhuT1vU" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/Npfx40VD3kM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/ZjF37uC4n-M" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/na5NvdfxOrM" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/RgyemIrnzsQ" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/lZACSaE2PHI" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/qtkesMe4ddE" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Hi Mike, do you have any coils that would fit a 2021 TRD Pro with the redesigned spring perch? Added some weight (100 lbs or so) and trying to offset the sag.
Sent from my SM-G986U using Tapatalk
KDSS spacers and long travel rear
On KDSS enabled vehicles (thinking of the GX 460 specifically), if one uses the KDSS spacers such as the one listed here (KDSS Spacer Kit | Treaty Oak Offroad), does that then make the long travel rear shock (e.g., IMS59-50575, MRA59-A575) and coils a viable option? If so, are there any extras/caveats to consider?
Thanks,
Rob
Thanks,
Rob
Some are using the LT coils and shocks with those spacers in stock, but I'm still not convinced that the system will last long term with those, and that the travel will also be had. The spacers add a good amount of drop to the sway bars, but the LT shocks extend a LOT further than the regular 701 length shocks. You can reach out to Treaty Oak and ask them too about their experience with the LT suspension and their spacers.
There are probably people on this thread running that combo, but no one has chimed in yet.
3" Lift With Long Travel
This may have already been addressed in the 197 pages of this thread already...so my apologies for not doing in-depth digging.
Summary/Goal:
Looking for IMS 3" Long Travel Lift on my 5th Gen 4Runner
Currently have:
-285/70/17 tires
-Front Weight: 60lb C4 front skid,
-Middle weight: 230lb C4 tranny skid/gas tank skid/sliders
-Rear weight - 130lb rear diff skid + Recovery Box in trunk + 285/70/17 full size spare
Question:
- Which coils should I purchase for front + rear for a leveled (little to no-rake) 3" long travel lift
-Options for front:c302/c314 or any other suggested option
-Options for rear: C59-599, c59-505, c59-325, or c59-675v or any other suggested option
Struts I plan to use are IMS59-50574 in front, IMS59-50575 in rear (as well as extended bump stops, extended brake lines, SPC UCAs)
Summary/Goal:
Currently have:
-285/70/17 tires
Question:
The rear LT coils are 3" of lift only, and to level out a vehicle, you have to lift the rear less than the front, which isn't really an option with 3" of rear lift.
3" front and rear looks pretty good on these and doesn't look really raked out in my opinion.
Only the rear coils that end in a V are long travel rears (the non-V coils can't be used with LT), and with the weight you've got, the C59-675V would be what I'd suggest, along with LT shocks, brake lines, bumps, upper and lower trailing arms, and panhard rod. Stock upper and lower arms will limit articulation and you won't have the full travel without changing them.
For the front, C59-302 on the IMS59-50574 struts is the most common setup to set to 3" up front with minimal weight.
