Dobinsons High Clearance Outer CV Stretch Boot Kit
Heffernan
Member
I'm looking to purchase a CV boot kit in the event that when I lift my truck a little more this spring, I'll have a CV boot kit incase one fails. I was just going to order a kit from Toyota (PN 04427-60141) but I stumbled upon Dobinsons High Clearance kit. I wanted to see if anyone has run these and/or if there a better option then just installing another OEM boot just to have it fail again down the road. Thanks.
Dobinsons High Clearance Outer CV Stretch Boot Kit for Toyota & Lexus
[MENTION=148378]Crikeymike[/MENTION] any more info you can give on these? I just saw these for the first time. How do they compare to a stock kit?
All the details of them are here: Dobinsons High Clearance Outer CV Stretch Boot Kit for Toyota & Lexus
These are high flex silicone, stock are not (just rubber from memory).
The bellow design allows for the boots to work at a steeper angle without each part rubbing against the other, which is what has them last longer.
PRWhite
