Dobinsons Long travel front struts and rear shocks
Due to popular demand, certain products have been added to our Amazon store just recently.
GS59-574 - for 3" lift - extended length front struts - 435/575mm - $145ea
GS59-575 - for 3" lift - extended length rear shocks - 432/730mm - $115ea
GS59-700 regular 2" lift front struts - 432/541mm - $125 ea
GS59-701 regular 2" lift rear shocks - 362/583mm - $95 ea
Products are now up for sale on Amazon, you can click on the price of each item above to direct link to that item, or you can follow this link then type in the part number you're looking for: http://www.amazon.com/shops/Dobinsons_USA
Any change of view on releasing the numbers for the rear variable rate spring weights? I know the Icon Overlands are 200/300, just wanna compare.
I did several months ago in the other thread with all our options. Here it is.
C59-675V - Variable rate comfort option, stock rear weight, 3" lift. 470/470mm, 16mm wire, 157-230LB variable
C59-677V - Variable rate comfort option, 400+LB heavy rear load weight, 3" lift. 500/500mm, 16mm wire, 157-230LB variable
And here's the thread with all coil specs: http://www.toyota-4runner.org/5th-g...-4runner-suspension-options-lots-choices.html
Where do you get the extended rear brake line if I wanted to run your 3" rear kit...? Which I do... lol
Also, you said you need a 2" lift front spring for the extended travel fronts. Which of your springs would recommend? Will be doing an aluminum bumper and winch. Don't want super stiff though...
This is the one we are using on our black truck, from Metal Tech.
https://www.metaltech4x4.com/fj-cruiser-4runner-extended-brake-lines-rear/
I think the C59-302 would be best then for you, those with the GS59-574 would be at 3".
The 300, 302, and 314 are all the same spring rate by the way.
Sorry I missed this, been on a trip. The biggest thing I want to get rid of is the brake dive. Are your spring rates stiffer than stock? Where does your shock valving differ? More high speed compression?
Feel free to pm me if needed. I'm ready to pull the trigger. Not really wanting to go coilover anymore since no one seems to be able to make a long lasting coilover anymore.
Also, if you order off of amazon are prices the same as going directly thru Dobinson? Everything in stock?
I responded to your pm but I dunno if it went thru. It's not showing up in the sent messages. I'm stuck in a s*** hole hotel in Chicago with terrible wifi. If you didn't get one let me know and I'll email or send me a number to call. Thanks!
I got it, replying now.
