Does my runner have no power rear window??
Special K
Hi all, had to sign up to ask this. I just bought my second 4runner. A 96 3.4L, 5spd, sr5. It has power everything, cruise, tilt, AC but I was under the impression that all 3rd gens have a power rear window. Looking at my rear window it looks like it should retract but I have no switch up front, or maybe I'm blind and can't see it.
Where is the stock power rear window switch supposed to be in a 3rd gen?
either up high on the center of the dash, near vents (where my 02 has it), or down by the ebrake (which I believe is where older 3rd gens have it)
tre is correct, but i will specify, on the pre cup holder trucks (yours is pre, changed in 99) the switch is on next to the hand brake. (where your hand would rest if your arm was on the center console) its right there.
Maybe yours has a manual rear hatch window:behindsofa:.
Just kidding! I couldn't find mine either when I first got it.:doh:
I have the same year sr5. It's next to the e-brake. Sometimes I wish it was an ejector seat button for the passengers.
Yours should be located same place mine is. Its just above the switch I flip in the video.
If its not working, you may have a wiring problem...or you may have the window locks on.
ahh ok, seems I'm missing the switch entirely then, there's a hole where the switch near the ebrake used to be. thanks all. I'll try finding a switch at the wreckers and see if that solves things
Pm me I have console out of 98 that I parted think switch is still with it can ck
When I return home friday out of town till then.dam job
averyberryman061493
