Doing front brakes on '95 4WD with Warn manual hubs - what to do differently?
T4R4ME
So, I'm doing my front brakes for the first time since I had the 4R. I've never done 4WD brakes before so I read up on here and other places and had everything ready to go. But there is one thing I didn't take into consideration, I got Warn manual hubs a few years ago and a buddy put them on. From the information for doing front brakes on a stock set up, what will I have to do differently with the Warn hubs? I started to take one apart, but it didn't look like any of my pics, so I figured I better ask.
Do the manual hub covers come off, then the manual hubs (how) and then I will start seeing everything I'm expecting to see (huge spindle nut, washer, etc.)?
I do have the install instructions for the hubs, but they're not very detailed.
Thanks!!!
Take off the nuts and cone washers and the hub should slide right off. The rest is a bit tricky, look for the c-clip on the spindle (hiding in grease and after the hubs are off). You will have a hard time taking out the inner race bearing (if you plan to change the seals and bearings while the rotor is off).
Just take everything apart and assemble it the same way it came off (but backwards).
good luck
