Dome Light Question
906-Runner
Dome light doesn’t work, fuse is good. Took the dash apart and it came on, but very dim. If I plug in the radio or pin d on back of the cluster the dome goes out. What would be causing it to go dim? How would I figure why it turns off once I plug the radio/cluster? Any help would be appreciated as it’s affecting radio and power door locks.
Truck is a 1999 SR5 4x4
Does it only affect the front dome light? What about the rear dome light or any other interior lights you may have?
it sounds like something may be significantly drawing power. is this a stock radio? how about ciggy lighter or electric fans going? to start some troubleshooting, use a voltmeter to verify that your 4R's battery voltage is nominal. also, pull the dome bulb out and hook it directly to a 12v source. if the bulb lights brightly when directly connected to some other source, then hook it directly to your 4R's battery and see if it lights brightly. also, see what happens with your other devices (like radio and power door locks) when there's nothing in the dome light socket.
how long has this been happening? did anything change recently? is this with the vehicle running or off? or either? if it's with the vehicle running, what is your alternator output voltage?
It affects both front and mid dome light, didn’t try it with the rear. It is an aftermarket radio. I did test the battery and it was 12.6 volts, so that’s good.
It’s only been doing it for a couple days, when I bought it a month ago the dome lights only worked in the on position, the clock and radio worked too.
I was trying to figure out why the door position didn’t work and following the advice of [MENTION=10169]TheDurk[/MENTION] I found on a thread from a few years ago I started to unplug stuff, and that’s when the clock and radio died and dome lights got dim. Plugged everything back in and now nothing works
I assume this is happening with the engine running as well as with the engine off? Have you gotten to a condition where the light is dim and measured the voltage and amperage across the fuse? You may be able to isolate where the problem is coming from by checking those numbers and seeing how they change based on what you have plugged or unplugged.
Dim, flicker or not on at all. Contacts were bad.
I got the autozone life time warranty ones. They are not cheep.
The door switch creates the ground to light the light. Unplug the door switch and ground the wire the switch plugs into. It should light the light. On the 96 all 4 were bad to some degree. On the 97 limited front two were bad. On my 97 SR5 only the hatch is bad.
Is it bright in the always on position?
Edit: the drawing shows an integration relay in the middle of all of it on my 97 EWD.
huh, that's really interesting. also a bit odd that a failing switch would make the light dim. you'd think it would be a binary kind of thing. maybe it makes and breaks contact like a confused relay.
my driver door switch went bad and not only id did it effect all the things your talking about , but made my door remote act crazy. While the dome did not go dim, I imagine it could depending on the switch or the grounding
Dome Light Don't Fit
I'm running into issues with getting an adequate LED dome light bulb...not sure if it is just my 2000 4runner or what, but none of the light bulbs I ordered fit. They are all too long.
1st. The Dome light is the one in the middle of the car right? If not then I am asking in regards to the middle one.
2nd. I tried to order from multiple sources such as Oznium and SuperBrightLED. They were all too big.
Thanks for the help in advance!:bump:
For my 97 DE3175 is the lamp and any led with that part number should fit. I bought 5w superb rights and when it burned out I got an led from autozone both fit perfect.
Ok cool I’ll try that out. Tired of paying these small companies shipping and return fees. Such bs. Thanks! Fingers crossed it works!
So it looks like I may have a bit more testing to do. I, going to guess its not the door sensors because why would plugging the radio and or dash in effect the lights? I will try taking the sensors of my parts rig and see if they change anything.
Probably not the door sensor. If your other doors do the same thing as the drivers door, its somewhere else. In my 2001 tacoma(same exact light fixture) it is dim all the time except just before the timer turns off it will flash bright. Also if I turn on my map lights it works perfect or if the key is on any of the on positions it works perfect. I need to test the voltage at the light and see if it is different under those circumstances.
The doors don't do anything currently. I'm trying to figure out why the light is so dim, and why it runs off when I plug in my radio and the dash. Specifically plug D, pin 12 for that is labeled DOME fuse. So something is drawing lots of power but I cant pinpoint what is. Anyone have an idea?
You have the wiring for your year correct? I don’t know if what I posted is accurate for your 2000
The 4Runner is actually a 99, I need to update my signature.
sorry to rehash. if you remove the dome light itself from the socket and hook it up to a separate 12v source, it glows brightly, as one would expect? have you switched out and put another bulb in its place, even temporarily with a wire lead if it's too small? if you don't have an extra handy, you could rob the vanity mirror light, for instance. are the connector prongs for the light clean with no corrosion?
with the vehicle off, what amperage do you read on your DVM, and the light is on but running dim? check in series with the light, then with no light, then with the light in place and in series with your battery negative and your battery negative cable. see the useful parasitic battery drain instructions that others (recently [MENTION=69868]LittleCaesar[/MENTION] on this thread ) have linked to on similar troubleshooting threads.
another thing to try, for grins, is to unplug fuses you *know* aren't involved with the dome light, and see if the dome light brightens. if i read your recent post properly, the light dims when you plug in (i assume you're meaning turn on) the radio. if the radio is not plugged in / turned on, the light is bright and ok? if that sounds accurate, then it's possible that your radio simply is drawing a *lot* of power due to some internal fault. if you're plugging it in, i'm going to guess you can hold it in your hand. does it get hot? if it's the culprit and is dissipating enough power to dim the lights, well wow... time for a new radio or at least see if an older or different one does it too.
there's a reason for 2ga wiring, deep-cycle batteries, and high-output alternators.
The lights are dome light themselves are good. I tested them straight off the battery and they are plenty bright.
I have the radio totally disconnected as well as the combination meter, that's the only time the lights come on but they are very dim. As soon as I connect the radio or the blue connector on the back of the dash they shut off completely.
I will try pulling other fuses to see if that changes anything but I'm convinced it has something to do with the combination meter. I filled up my gas tank yesterday, went to reset my trip odometer and it was at like 35 miles. Reset it anyway and drove home (5miles). Started it up to head to work this morning and it had reset itself. Every time I turn the truck off and it sits the odometer resets itself.
SO would I be correct in thinking the dash itself is the problem?
