Dome lights/radio not working 95 runner
TACTICALMEDIC-T4R
Hey gents,
The other day i went out to move my yota and noticed the radio didn't come on, So i checked the kick panel and seen a blown fuse, replaced it and nothing. For some reason i tried my blinkers and the right blinker would blow the 10a in the kick panel, So i checked the dome fuse under the hood and that was blown, when i went to change it, it blew again and again, The only things not working are the radio,int door lights and dome. When i turn my left blinker on it works fine but when i turn the right blinker on dash lights and headlights flash a bit a it blows the fuse. Not sure what happened it was working fine yesterday and hadn't driven the truck for for 3 days.
You have a short somewhere, blowing your fuses. If it rained recently, check for areas where water would collect and wires could make contact.
1st step is check BATTERY. Have it load tested at an auto part store, its FREE.
Suggest you charge it up first, then take.
What truck-year-model-engine?
Looked at the schematic to see what's common to all that are not working?
Concur. Got after market trailer wiring? Check that.
1st step is check BATTERY. Have it load tested at an auto part store, its FREE. Suggest you charge it up first, then take.
WHAT???????!!!!!!
brendaglores
