Door stop checks
Dirt Demonl
Hello all, Im wanting to know if the door stop checks are reversable from one side to the other? Im unemployed right now, and cant really afford to buy them. Both front and rear passenger side are good, and fixing this would make a happy wife,,, Thanks for any help,Frank.
I was just looking at this about a month or so ago, and as I recall the LH and RH are different. If you could flip the "arm" I think you could swap them, but the arm is riveted to the rest of the check.
I tried replacing my drivers side with one I picked up cheap at a junkyard, but it was well worn also. Ended up forking over the ~$70 for a new one from camelback.
Not to hijack the thread - but I have one that is squeaking. Is there a recommended lube? I don't want to reduce the effectiveness of the check with grease, yet I need to eliminate the squeak...
tuṣṭāva
