Downey w/Doetsch Tech
mforce
I have a friend of mine that has a set of Downey with Doetsch Tech shocks. Both are brand new never been installed. They have a 3" lift. I am able to pick them up for less then $200. Are they worth it and are they any good. This is for the rear only.
I have a friend of mine that has a set of Downey with Doetsch Tech shocks...
Downey coil springs maybe?
Downey stuff was pretty decent, depending on what DT shocks, it's probably worth $200. What are you going to do for the fron?
Not sure on the front. A budget is definitely in mind here as well. What would you recommend? I was thinking about Bilstein with my stock springs and Daystar spacer.
I am on a budget for this build anyways. I don't want to have to extend brake lines and drop panhard and all that. I know I will have to do the diff drop.
What about if I use Bilstein 5100's with my stock springs? I have 20 1/2" from center of hub to fender so the springs are sagging and I just want a small lift since it is still the family hauler for me. I am thinking on the 5100's and a diff drop then I should still be good to go?!
