Downstream Oxygen Sensor
OkieMedic
So, I had a little mishap on the trail last week. Somehow had a downed limb pop up and literally pull all 4 of the pins and wires out of the connector of the downstream oxygen sensor. I have no idea which wire goes to which position in the connector, so i was going to buy one and try to line them up based off that. I started looking online and it looks like there are 2 different part numbers for downstream sensors. one for Left and Right. How the hell can you tell which is which? Because there is no left and right (as far as I can tell). It is just a single sensor in a single pipe.
OR if someone happens to have a wiring diagram, that would be a big help as well.
ECU Harness side:
Sensor side:
Wire colors 2010 ewd, later years may vary:
