Drive Train Fluids - Suggestions and Questions
Asssuming the transmission holds 12 qts total (FSM is somewhat ambiguous, but that's close), and you drain and replace 4 qts each time you do it, then the percent of new fluid is given by the following formula
100*(1-(8/12)^N), where N = number of times you drain/fill.
Example. 1 drain and fill. (8/12=.667)
%new fluid = 100*(1-.667^1)=33%
Example: 3 drains and fills
%new fluid = 100*(1-.667^3) = 70%.
And so on... Takes about 6 cycles to get to 90%.
My plan going forward is to do a drain-fill at each oil change for the next 3 changes, and then every 3rd oil change after that. That should pretty much turn over the fluid every 100K miles, which for my driving model (<2000 miles of light towing/year) should be adequate.
I think that's a bit overkill, as I pointed out before it's not at all about getting all the old fluid out (you can't, not unless you take apart the transmission and scrub every last spec of varnish/grime off all the components); but replenishing the additive packages and majority of the fluid. You can't do a 100% fluid exchange no matter what you try, which is why Toyota is find with just drain & fill a couple time.
But it's your vehicle and if that's the service interval you want to use, it's not gonna hurt anything to do that. I personally am going with 100k and then 50k intervals to match the coolant service intervals (first coolant service for all Toyota vehicles using SLLC "Pink" is 10yr/100k followed by 5yr/50k intervals).
You're probably right, but if you go back to the oil analysis I posted earlier in this thread, my fluid has a pretty high metal content currently, which is why I want to be a bit more aggressive early on with the drain/fills to get things cleaned up a bit. I'll send another sample in for analysis after two more drain/fills, see where I am, and go from there.
Thanks for your insights.
I'm just amazed that OP is changing tranny fluid at 30k miles. That is crazy and a huge waste of time and money. ~100k makes sense.
I am not going to do the drain and fill tranny fluid method . my plan is and on other vehicles drop tranny pan . clean up the pan and the pan magnets .
then add the same amount of fluid plus 1/2 qt . run it and check for proper level.
it is more work but the metal from break in and machining of new is mostly removed.
a new tranny will have more metal in the fluid..
flushing is good if its contaminated like antifreeze or water etc...
I would never flush with a dirty pan.
Speaking of fluids....here's a question for you all. I have heard a rumor, from a mechanic. I'm considering changing the gear oil in the front and rear diffs to Royal Purple. I have a 15 TEP and it has the locker, but I was told if I shy away, and use the other fluid, it will ruin the locker. My mechanical brain says this is hot garbage, but I want to know if anyone else has seen or heard anything like this? I absolutely do. Or want to have to buy a new locker over some damn fluid.
Locker requires no special lubrication. Someone probably getting limited slip mixed up with a mechanical locker.
I run Lucas 85/140 non synthetic in mine. It's not the best for mpg, but helps with off-raoad use.
I am on the fence with what I want to use, Amsoil, Royal Purple or Lucas. I just want to make sure that having a good feeling putting the fluid in, is going to make my pocket feel bad later....
Why not OEM? Just use what they do and there are no problems or issues.
That is an option, I always look to see if there are better options out there though. As an example I used to use royal purple in all my diffs in several other vehicles because it's good up to about 50k. Otherwise, and I'm a pretty firm believer in changing the other fluids every 30k. That just happened to be an example where they made a superior product. But I'm kind of feeling my way through this one...my 5th gen that is.
premiumusedautoparts
